26th Apr 2018, 2:37 pm | #21 |
Re: Fidelity HF 43 Record Player
Yes, but thiis will be just the same with 4 pins. This was suggested as the X5M is in very short supply and many sellers are now out of stock. The X5M is the best and easiest option if you can still get one.
Edward. |
26th Apr 2018, 3:06 pm | #22 |
None of them will be as loud as your original cartridge as they're 'ceramic' rather than 'crystal'.
Before going any further, have you actually confirmed that your X5M crystal cartridge is faulty? |
26th Apr 2018, 9:03 pm | #23 |
In my experience the bsr x5s and x3s can be brought back to life by carefully opening them up and cleaning the contacts, you have to take great care when doing this as the contacts inside are very thin and can tear easily.
I've done lots of these and never had a problem with them. Worth doing it will save you money you don't have to spend anything to do this. |
29th Apr 2018, 8:58 am | #24 |
OK. Restoration is going well, but there is another issue. Decided to have a closer look at the cartridge but now looks as if I need to rewire the tonearm! Have been looking at these copperwire tonearm kits that come with the copper wire, cartridge clips, solder etc. Would it be OK to use such a kit on the player I have? ie:are they universal and can be used on most players/turntables ,or are they just for specific turntables?
Once again, any advice greatly appreciated. |
29th Apr 2018, 9:40 am | #25 |
Why do you need to rewire the arm?
29th Apr 2018, 10:18 am | #26 |
Hi there. Thanks for your reply. I attempted to take the cartridge out without realising that the tone arm wires were soldered/heatshrinked onto the cartridge. So now I'm fearing that the wires may now not be long enough in order to fit a cartridge back on. Hence me thinking of getting one of the tonearm kits.
29th Apr 2018, 10:25 am | #27 | |
Hi there. Thanks for replying. Haven't actually checked but just have a feeling that because of its age that it could be better. How can I tell if it is faulty?. |
29th Apr 2018, 10:31 am | #28 | |
Edward. |
29th Apr 2018, 10:32 am | #29 | |
29th Apr 2018, 12:22 pm | #30 | |
29th Apr 2018, 12:31 pm | #31 |
No, it would not have been made that way. The rubber sleeves will usually conceal the connecting tags - are you quite sure they are not there?
Soldering directly to the cartridge pins would most likely ruin it and no Manufacturer would do this.
Edward. |
29th Apr 2018, 12:33 pm | #32 |
Hi Edward. Hopefully I've uploaded the picture properly. This is the cartridge before i dismantled it. As you can see there's no cartridge tags included. Thanks again.
29th Apr 2018, 12:38 pm | #33 |
Normally inside the sleeving, can't quite tell from that photo.
Lawrence. |
29th Apr 2018, 12:53 pm | #34 |
That blue corrosion doesn't bode well for the cartridge. It's probably caused the tags to stick to the cartridge pins, resulting in the wires breaking before the tag came off. With luck there will be a bit of slack somewhere in the wiring, but you'll likely need new tags as well as the cartridge.
29th Apr 2018, 1:09 pm | #35 |
Thank you for your replies. Could not see any tags at all. Plus they were so tough to get off, the wires had broke as well as the pins looking very corroded. Yes hopefully there will be some slack in the wires, but I may have to go down the rewiring route.
29th Apr 2018, 6:49 pm | #36 |
Connect the spare pair of wires in the arm to the cartridge, disconnect the other ends from the tag strip under the deck, then connect them to where the existing wires are connected to that strip. Saves a lot of work!
29th Apr 2018, 6:50 pm | #37 | |
Thanks again. |
29th Apr 2018, 7:04 pm | #38 |
The blue corrosion suggests that the crystal inside has absorbed moisture and disintegrated. I very much doubt this cartridge will be of any use.
29th Apr 2018, 7:42 pm | #39 |
Well we did tell you they would be there! Yes, they are very small and delicate. Clean the pins/connectors with a very fine emery cloth. I would cut the rubber sleeves off and then push the tags back on with small tweezers. With no sleeve on, you can see how well they are fitting. Just make sure they don't bridge each other. This is the kind of thing we restorers do all the time and this action often can bring the full sound back. But, if you do find no improvement, you need to get a replacement cartidge - so don't delay.
Edward. |
29th Apr 2018, 8:48 pm | #40 |
Thanks so much everyone for your kind help and comments. Will take all your advice and knowledge on board and will do my best to bring it back to life and will let you know the results.
Much appreciated! |
