Old 12th Nov 2017, 4:21 pm   #1
dragonser
dragonser's Avatar
Default PowerMac 7600/120 ethernet question
HI,
I have just powered up a Powermac 7600/120 using os 9.1 and have tried to get the internet connected. But no luck.
well I guess I have to setup the tcp/ip , does anyone know know how to do it ? it is probably something reasonable obvious.
Like everything I guess it is simple when you know how to do it !
Regards Peter B
dragonser is offline
Old 12th Nov 2017, 5:23 pm   #2
OldTechFan96
OldTechFan96's Avatar
Default Re: PowerMac 7600/120 ethernet question
I think that this Macintosh has Ethernet built in so connecting to the Internet should be straightforward.
Apple menu-->Control panels-->TCP/IP-->connect via Ethernet.
Your IP should be automatically found with the autoconfig option.
OldTechFan96 is offline
Old 13th Nov 2017, 12:08 pm   #3
dragonser
dragonser's Avatar
HI,
I will take some screen shots of the various menu's. Yes it does have an ethernet port built in, but the way of getting the setting autodetected isn't obvious ( at least to me ).
Regards Peter B
Old 13th Nov 2017, 12:14 pm   #4
paulsherwin
paulsherwin's Avatar
This is normally the default setting. Have you tried just plugging it into your router?
paulsherwin is online now
Old 13th Nov 2017, 6:05 pm   #5
dragonser
dragonser's Avatar
well the light on the router came on when I plugged in the cable. but using a browser meant i just got an error message after a short wait. I know that the machine was originally used with blue yonder probably ten years ago. I will try some more things and let you know what I find.
Regards Peter B
Old 19th Nov 2017, 11:14 pm   #6
dragonser
dragonser's Avatar
well I tried it again tonight and it worked ! I have taken a photo of the settings and must make a note of them !
Regards Peter B
Old 20th Nov 2017, 1:21 pm   #7
OldTechFan96
It's good to hear that you have sorted your problem.
I would recommend the web browser Classilla. I use it on my PowerMac G3 with good results.
Old 21st Nov 2017, 8:41 pm   #8
dragonser
dragonser's Avatar
thank you for the suggestion of classilla, I did find that the existing browser doesn't have the security facilities that many login systems require !
I have a lot to learn !
Regards Peter B
