31st Jan 2006, 10:39 pm | #1 |
DAC90A Tuning scale edging
I'm new to restoration and glad to have found such a great website - full of useful information. Well done. My immediate problem... I have 2 Bush DAC90As that I am restoring - probably sell one and keep one. The tuning scale has a rubber/platsic edging that has deteriorated on one of these and gone brittle. Does anyone know where I can get a suitable replacement? Thanks, Bob |
1st Feb 2006, 1:43 am | #2 |
Re: DAC90A Tuning scale edging
Hi Bob and welcome to the forums.
Those rubber bits on the tuning scales will be found on virtually all old radios where the scale is glass and on many perspex-scaled radios too, although the latter often use nothing more than lengths of cream coloured sticky tape. The answer to your question is simple - make your own replacements. You can cut pieces from something like a rubber glove, a bicycle inner tube or even from pieces of cable pvc outer sheathing. That used on 3amp mains cable is ideal; remove a length of sheathing, cut a slit in it and away you go. I've even used bits of insulating tape, often with two or three layers to obtain a suitable thickness. Thickness is quite important; to protect the glass and also to prevent the scale from rattling about loose. Good luck with the DACs |
1st Feb 2006, 7:12 am | #3 |
Thanks Darren. I had thought of making my own but it looks like the sort of channeling that would still be made for some purpose or another. I like the idea of mains cable insulation.
Bob |
1st Feb 2006, 7:57 am | #4 |
Sometimes I use sticky back foam insulating tape like draught excluder in black or if I want a more authentic look I buy rubber trim such as for windows etc from car accessory shops. and cut to size. I must say I like the idea of sheathing from maims cable, hand't thought of that.
1st Feb 2006, 9:00 am | #5 |
Hi Gents, it is available, when I worked at Ferranti we used for the edges of panels as a protection and for covering "raw" edges, made by one of the gasket manufacters but which one I'm not sure.
HTH Ed |
1st Feb 2006, 9:17 am | #6 |
Hi.
Try this chap. I have bought some from him before. Hopefully he still has some. It's a little pricey @£1.50 a length, I think it is worth it though, as it is the correct square section stuff. http://www.valvedwireless.co.uk/ |
1st Feb 2006, 9:24 am | #7 |
Ian Liston-Smith in his article in the BVWS Bulletin(Winter 2003) says he got his from Camber TV. I've been to the site: Camber TV & Video Centre, 01797-225457 (daytime). East Sussex (T).
Don |
1st Feb 2006, 7:02 pm | #8 |
I'd be wary about using anything self-adhesive on the scale, as the glue may eventually attack/pull off the screen printing.
Hacker transistor sets (e.g Sovereign, Herald) used self-adhesive foam around the upper and lower edges of the Perspex tuning scale, and they all look awful now And if you didn't already know, Bob, treat the scales with great respect. Clean the reverse with nothing more than a slightly moist cotton bud in the transparent areas only, and be ever so careful that your screwdriver doesn't slip when removing/re-fitting them. Damage is suprisingly easy to cause (even if you're experienced), looks horrid when the scale is illuminated, and can spoil the whole look of your finished set. Nick |
1st Feb 2006, 11:00 pm | #9 |
Greenhouse black glazing bead - perfect (square U section). Although you may have to buy about 50m .
Jim |
