2nd Jun 2019, 4:38 pm | #1 |
Ferguson personal contrast and sound issues
2 issues with this tv . The contrast control does nothing what so ever. The pot tests fine but that’s as far as I have gone. The picture is not to bad even without it working.The other problem is i can only just and just here the sound on 405 lines with the volume control on full i get some background hum so the amps working and it works fine on 625 lines . I know my 405 line feed is good as I have no problem with my other TVs . It does get slightly louder for a fraction of a second if i pull the aerial lead out then put it back in.
Most of the capacitors have been changed but not all. I’m not sure I want to spend to much time on this set as the cabinet is not in the best condition .this set has grown on me abit though . Any help would be appreciated Andy |
2nd Jun 2019, 5:05 pm | #2 |
Re: Ferguson personal contrast and sound issues
Is this the little 11" CRT version of the Thorn 900 chassis, model 3629?
For the contrast control issue, there is usually a high value resistor (in the order of 2 -5 MOhms) fitted between the slider of the contrast control and the vision AGC line. This may well have gone o/c or very high value. Last edited by dazzlevision; 2nd Jun 2019 at 5:07 pm. Reason: Added text. |
2nd Jun 2019, 7:32 pm | #3 |
Thank you Mr Dazzlevision .you are correct that is the same set as in your picture and you are correct on the resistor . It’s should have been 3.9 M but it was over double that. I just fitted a new one and that’s sorted the contrast.
Hopefully someone can give me ideas to the sound problem. Thanks again Andy |
2nd Jun 2019, 9:25 pm | #4 |
First guess is the sound detector diode, probably O/C J.
2nd Jun 2019, 10:59 pm | #5 |
I've got one of these and it does display a lovely picture .
Cheers Neil. |
3rd Jun 2019, 1:24 am | #6 |
Yes Neil so far I would agree he picture is very good
John i will investigat the detector diode when I got abit more time. I guess it’s in one of the If cans . Thanks Andy |
3rd Jun 2019, 2:34 pm | #7 |
John . Almost spot on . It was a bad joint on a component next to it.
Thanks . Andy |
11th Jun 2019, 3:18 am | #8 |
The sound should be strong and powerful on this model. Would've been ideal if they had VHF radio facilities.
Out of interest, does yours have a valves or transistorised UHF tuner? |
11th Jun 2019, 9:19 am | #9 |
Agree. It employs a PCL86 sound output valve, enough to blow you out of the room!
Ferguson always designed a good sound channel/output stage to provide adequate sound under poor reception conditions. Something other leading manufacturers should have taken a note of. John. |
11th Jun 2019, 2:57 pm | #10 |
I can’t believe how well this set preforms both picture and sound. It does have a Valve UHF tuner slightly critical about the correct tuning but performance is very good .
I like this set so much I wouldn’t mind a second one for my workshop . Only thing is I want some replacement tuner and knob copper brights but I guess I will have to try and make my own as I’m sure everyone with these sets wants them as well Andy |
11th Jun 2019, 5:47 pm | #11 |
Valve UHF tuner grand now when fed with strong (sometimes too strong) signal from modulator etc - not so great back in the day when presented with weak broadcast signal
11th Jun 2019, 7:37 pm | #12 |
The super bright high contrast picture can be put down to the PFL200 video output and sync separator valve introduced in 1964. 21 m/a per volt, a great valve. J.
11th Jun 2019, 7:58 pm | #13 | |
My example has a PL500 line output valve, albeit Mullard, suggesting a '60s replacement. |
11th Jun 2019, 11:34 pm | #14 |
I did have a go at making a replacement bright for my set which was basically the bright from a scrap knob. just don't look too closely at it..
Cheers Neil. |
