Old 30th Sep 2017, 2:53 pm   #1
DonaldStott
DonaldStott's Avatar
Default ABS Box
Don't know if this the correct place to Post this ...?
What's the best tool to use to cut a 3" diameter circular hole in the lid of an ABS plastic box.
BVWS Member
DonaldStott is offline
Old 30th Sep 2017, 3:05 pm   #2
ms660
ms660's Avatar
Default Re: ABS Box
Hole saw or Forstner bit, not too fast, job clamped to a fixed backing board of suitable thickness.
Lawrence.
ms660 is offline
Old 30th Sep 2017, 3:06 pm   #3
G6Tanuki
G6Tanuki's Avatar
Default Re: ABS Box
What I'd use is a "tank cutter" fitted in a drill-press.
For example http://www.thanettoolsupplies.co.uk/...147e20df28981a
Run it fast, and apply *very* gentle feed pressure. I've drilled holes in Perspex/Lexan this way.
G6Tanuki is offline
Old 30th Sep 2017, 4:39 pm   #4
Biggles
Default Re: ABS Box
If using a handheld battery drill be sure to use the torque clutch on it. If it snags it can't half give your wrist a snap. Make sure the work is held securely, as has been said before. With ABS be sure you don't overcook it and melt the plastic with friction of the cutter. All from bitter experience.
Alan.
Biggles is offline
Old 30th Sep 2017, 5:22 pm   #5
emeritus
Default Re: ABS Box
For thin plastic sheet up to 1mm, and plywood up to 4mm I have used a Swann-Morton No 11 scalpel blade clamped in the ink nib of a par of compasses. Drill a very small hole to establish the centre, and cut from opposite sides.
emeritus is offline
Old 30th Sep 2017, 6:25 pm   #6
Andrewausfa
Andrewausfa's Avatar
Default Re: ABS Box
Depending on the material, other than the hole saws mentioned above, you could use one of these. Also useful for cutting out felt washers for the back of knobs and also sorts of other circular plastic parts. For plastic reverse the blade so you are scoring the material rather than slicing, otherwise it tends to skew out of the 'cut'.
https://www.amazon.co.uk/Olfa-Compas.../dp/B000BK7NWC
Andrew
Invisible airwaves crackle with life. Or they should do.
BVWS Member
Andrewausfa is offline
Old 6th Oct 2017, 6:32 pm   #7
DonaldStott
Default Re: ABS Box
Not a bad attempt using my hole saw - see picture below (but don't look too closely!).
Thanks to everyone for their recommendations.
BVWS Member
