Old 21st Mar 2015, 2:09 pm   #1
FERNSEH
FERNSEH's Avatar
Default Aurora works well on six volts.
I'm trying out two new Aurora SCRF405 standards converters on a six volt supply. No problems whatsoever. The power suppliers are from defunct Pace Freeview boxes, the very early strange shaped unit that was made not long after the introduction of digital TV in the UK.
DFWB.
FERNSEH is offline
Old 22nd Mar 2015, 12:36 pm   #2
FERNSEH
FERNSEH's Avatar
Default Re: Aurora works well on six volts.
As a follow to my last post about operating the Aurora on a 6 volts supply. Although it would appear the converter will operate on such a low supply voltage, it is unwise to do so. Nine volts is the recommended supply.
The reasons for not operating the Aurora on less than 9 volts is explained here: http://forum.radios-tv.co.uk/viewtop...112939#p112939
DFWB.
FERNSEH is offline
Old 25th Mar 2015, 11:16 pm   #3
kan_turk
kan_turk's Avatar
I run my auroras off stabilised 7.5v with no problems - I found that at 9v they run hotter than I would like - I also use external heat sinking on 'F' connectors which I have found to be very effective.
I appreciate that some may regard this as overkill but I believe it helps if equipment is run as cool as possible
John
kan_turk is offline
Old 26th Mar 2015, 5:10 am   #4
julie_m
I think you got lucky running it from a 6 V supply; the regulator is just on the bounds of its sensible operating region. If you were on a real milliwatt-saving trip, you could get a 5V regulated switched-mode plug-top PSU and bypass the Aurora's regulator. Using a micro-USB connector for the regulated supply would reduce the risk of plugging in an incorrect PSU.
julie_m is offline
Old 26th Mar 2015, 10:59 pm   #5
Hybrid tellies
Hybrid tellies's Avatar
I use a switched linear psu on mine and find that I get a 9v output to the aurora with the PSU switched to 7.5v output.The Aurura now runs much cooler and it's nice to know that I am feeding it the correct voltage.
Simon
BVWS member
Hybrid tellies is offline
Old 26th Mar 2015, 11:50 pm   #6
mark pirate
mark pirate's Avatar
Although you can run the Aurora at 12v, it is much happier at 9v. I run mine on a good quality regulated supply. The voltage under load is was 8.9 volts.
The cooler it runs the longer it will last!
Mark
mark pirate is offline
