14th Oct 2018, 11:06 pm | #21 |
Re: What is this 1930s Cabinet Radio?
Sets of that age can have some very interesting designs. The "experimental" age of the 1920s was over. Radios were evolving to look less like slightly-scary laboratory instruments that were the preserve of the eccentric scientist, and more like something that rightly belonged in a "normal person's" home -- but nobody yet had an idea of exactly what a radio receiver "should" look like.
15th Oct 2018, 12:09 pm | #22 |
I think it has something of an Ultra look about it.
15th Oct 2018, 1:33 pm | #23 |
15th Oct 2018, 1:50 pm | #24 |
The tuning dial is clearly pre-1935, and the radio section valves are of the earlier balloon shape rather than the shouldered shape which was introduced in 1933 (although they were available long after). I would be suspicious of the MU14 rectifier, as this is a high heater current + high DC output (120 mA) device - the two radio valves would have required no more than 50 to 60 mA, and it is possible that this rectifier valve was a handy replacement for an earlier one with lower output. Critically,though, at 2.5 A heater current, this may be overloading the mains transformer, since early 30s rectifiers operated with 4 volt 1 amp heaters. Pick-up sockets were fitted to some radios from the late 1920s so the set must lie within the period 1929 to 1934; knowledge of the valve line-up would help with the date. The post about Smith's clocks would suggest 1931 to 1933 as the period, whilst the dial appears to be calibrated not in degrees but in metres, suggesting 1932 - 1933 as the probable date.
15th Oct 2018, 7:57 pm | #25 |
I've taken the back off again and snapped a couple of pictures. Sorry about the picture quality, it was dark. The valve with the red wire attached is a Mazda AC/SG. The green wire goes to a Mazda AC/PEN. The valve with the grey coating isn't marked at all. The dial is calibrated in metres.
Now you've got me worried about the MU14. If its the wrong type, what should the rectifier be? |
16th Oct 2018, 3:01 pm | #26 |
These are all B5 based valves, which further supports the pre-1933 date since the B7 base was introduced from 1933 for new developments. The unmarked valve is most probably a triode (it looks like a Marconi MH4). Given the presence of the AC/SG and AC/PEN (both Mazda B5 based with side contact), this may originally have been an AC/HL, but set makers in the 30s did not always use a single valve manufacturer in their line-ups.Total HT current would therefore be around 42 mA. All the heaters are rated at 4 volts, 1 amp. The original rectifier could be expected to have a similar heater rating, and be capable of delivering 60 mA, so, on the assumption that indirect heating was a requirement (to limit the charging rate for the smoothing capacitors), a Mazda UU2 (equivalent to Brimar R1 and Ever-Ready S11A) should fit the bill. The only proviso is the measured AC voltage being applied to the anodes, which for these valves should be 250V AC or less. If more than this and less than 350V AC, then a more modern rectifier would be needed.
High current rectifiers were introduced in 1933, so it may just be that an MU12, IW3 (later IW4/350), or A11B was indeed fitted to the PSU as it may have had other applications besides this radio. Although frequently regarded as equivalent to the MU12, and sometimes marked as MU12/14, the MU14 will deliver higher voltage at higher current than the MU12. Pre-war higher efficiency specimens were extracted from the production batch and marked MU14, whilst the less efficient ones were marked MU12. Much later production saw them marked MU12/14. |
16th Oct 2018, 9:09 pm | #27 |
The picture in post 25 of the clock face is interesting as very few clocks I've encountered used that unorthodox typeface and arrangement of numerals.
Barrie Smith's book has a picture of an identical face & bezel, on a single model called the "Bath", which Barrie states was only listed in the 1933 catalogues. HTH, Nick. |
17th Oct 2018, 9:24 am | #28 | |
17th Oct 2018, 9:26 am | #29 | |
17th Oct 2018, 10:06 am | #30 |
A most interesting find and I would not be able to wait and get it running.
17th Oct 2018, 10:14 am | #31 |
Yes, genuinely rare.
You look like you have the right kind of decor to accomodate it somewhere |
17th Oct 2018, 10:49 am | #32 |
It's actually growing on me, with the door shut you wouldn't know it's a radio too.
The interesting speaker position in the cabinet would give it a very good bass reprocess but not much treble. I would imagine with the radio on an unexpecting person would be puzzled to know where the soft / deep sound would be coming from.
Clive |
17th Oct 2018, 8:38 pm | #33 |
Well actually I've had it for twenty years and I'm finding we dont really have a huge amount of space for it these days and it might have to go. Sounds daft after finding out more about it in the last few days, but I've never quite got round to investigating it before now.
20th Jan 2019, 11:45 pm | #34 |
Hello. Not at all an expert but I've just found an old radio in the loft and this was the only place I found any reference to the Bela British brand. Here is a pic of it.
21st Jan 2019, 12:52 am | #35 |
A very striking cabinet. I've never seen anything like that before at all-very impressive! "Sets of that age can have very interesting designs" post 21* Julie-you weren't kidding! Perhaps someone should tell unclemanly that he's not alone. There has been no contact since October when he was talking about a lack of house room! You're telephone would probably be of great interest as well pad!
Dave W Last edited by dave walsh; 21st Jan 2019 at 12:59 am. |
21st Jan 2019, 9:22 am | #36 |
It looks a little like a baseboard set that has been put into a cabinet, the two made separately, either by manufacturer or an amateur. Early 30's - be interesting to look inside!
21st Jan 2019, 11:17 am | #37 |
Looks like an Ultra cabinet?
21st Jan 2019, 12:42 pm | #38 |
On reflection, the only thing it reminds me of [with the square section] is a very ornate side board I once saw but that was enormous!
Dave W |
10th Feb 2019, 5:42 pm | #39 |
Reminds me of USA Westinghouse or just Skyscraper Wood Clock/Radios from the early 1930's.
15th Mar 2019, 8:34 am | #40 |
Just found this, same concept from the USA.
Clive |
