Old 22nd Jan 2018, 3:56 pm   #1
Doris The Diode
Doris The Diode's Avatar
Default Levell PU33 PSU Fixed
I wanted to share how I fixed my PU33 PSU/battery eliminator in my TD200DMP sig gen.
There doesn't seem to be any info or diagrams for this particular PSU, not that I could find so took some photos of the unit.
The fault was that one of the 150uF 40V capacitors had bulged and went faulty, which then gave me about +10V - 10V on the rails.
I replaced them both with four 330uF 35V capacitors, putting two in series to make up 165uF at 70V, close enough.
Please also find the circuit diagram below, off load values and on load values should you need to fault find.
The 8V2 zener diodes are behind the 9V battery connectors on the outside of the metal case.
The 1K2 resistor does get hot and my guess that it is around 3W in value.
I didn't measure the current drawn on the rails.
Cheers,
DD
ID:	155917   Click image for larger version
ID:	155918   Click image for larger version
ID:	155919   Click image for larger version
ID:	155920   Click image for larger version
Doris The Diode is offline
Old 26th Feb 2018, 10:26 am   #2
vinrads
Default Re: Levell PU33 PSU Fixed
Well done with the fix, when I have a piece of modern equipment to repair I always check the capacitors in the power supply .Mick.
vinrads is offline
Old 4th Mar 2018, 11:27 am   #3
Phil G4SPZ
Phil G4SPZ's Avatar
Thanks for sharing the story and the reverse-engineered circuit! Well done.
Phil
Phil G4SPZ is offline
