27th May 2014, 8:17 am | #1 |
Modern Equivalent Thermistor
What would be the modern equivalent of STC R53 thermistor?
27th May 2014, 9:14 am | #2 |
Re: Modern Equivanlent Thermistor
There isn't.
I assume it's for a wien bridge oscillator? Later designs went for rectifier and variable resistance FET control. Earlier designs ran higher power and used a small light bulb ('Bill's Bulb') Current audio source designs compute phase then use a sine look up table in ROM and stuff the result into a DAC and filter. David
27th May 2014, 9:48 am | #3 |
A pity this is no longer available. I have used a number of these in the past and it is possible to construct an oscillator which is stable, simple and uses a handful of components, yet manages to produce distortion below 0.05%. I suppose the easiest route these days would be the overkill of using a DDS device, but as wrangler has stated - a filter would then be required to get a really good distortion figure.
Progress? I rather think not! |
27th May 2014, 4:38 pm | #4 |
Re: Modern Equivalent Thermistor
Oh well never mind, will have to go new school route for signal source and use Audacity. Generating the frequency that I desire to control the motor on a loop. Or alternatively record the signal to tape and use my Ferrograph continuous loop tape spool to do the controlling.
That's as technical as it gets for me, I know there is a whole raft that you can now do in the digital domain but out of my scope. The Heathkit AG-9 needs a complete refurb but that uses the 3 watt 120v bulb in the feedback circuit. But that will have to wait for another day. |
27th May 2014, 7:04 pm | #5 |
I have an R23 and an R52 thermistor if you think they are near enough equivalents to be of any use. They are both tubular glass about 25mm long by about 10mm across.
Alan. |
27th May 2014, 8:54 pm | #6 |
The R23 looks pretty close: an R53 circuit would just need a small change to one resistor value to accomodate.
John |
