21st Oct 2022, 12:34 am | #81 |
Re: Yet another MK14 vdu card
I have definitely seen IDC female sockets but not recently, and don’t remember seeing IDC male plugs.
21st Oct 2022, 8:06 am | #82 |
IDC male and female PCB mount and IDC female cable mount are still current and widely available, but the DIN card rack connectors are maybe less so nowadays. Have you ever seen a DIN 4xxxx data connector designed to clamp onto a flat ribbon cable? I don't think I have.
21st Oct 2022, 9:06 am | #83 |
Rapid has a cable mounting 41612 connector (Order Code: 51-9676) , so presumably others with a wider range of stock would too. Although where you get the 64 way ribbon cable from is a good question....
21st Oct 2022, 9:48 am | #84 |
For Coolsnaz2's proposed one-to-two splitter cable one of the three cable mounted connectors would have to be male, the other two female. Are they available in both 'sexes'? (At work, don't have time to look).
21st Oct 2022, 10:07 am | #85 |
Sadly it looks like they only have the female type. Farnell has a range most of which are marked "no longer manufactured" which is not a good sign either, unless you've got that time machine working....
21st Oct 2022, 10:12 am | #86 |
Digikey has male and female a+c style connectors, at about £12 each....
21st Oct 2022, 11:17 am | #87 |
I think Tim and Cs2 both use the more closely spaced a+b row type but it seems possible Digikey etc may have them in their range, again, don't really have time to look.
24th Oct 2022, 8:27 pm | #88 | |
Attached photos shows Realtime's Invaders program running on my original MK14 and original VDU card. Sorry about the top line being missing, this is due to the old TV being used. |
24th Oct 2022, 8:46 pm | #89 |
It amazes me how often we mention something off-hand, and you quietly go away and several days later, it's done. So that's great to see, Invaders running on nearly all original SOC hardware (there never was an official 'RAM pack' for the 0200-07FF slot from SOC, so homebrew was always the only way to go).
I don't recognise the TV (though there will be plenty of people on the forum who do). Do you know what make / model it is? Edit: I see Alba, but I still don't know the model. It probably has a 'V-Height' control around the back somewhere, it may even be poking out through the back of the set. They also sometimes have horizontal width and / or horizontal shift controls which might let you centre the image a bit more - however the latter issue is the purely fault of the SOC VDU design, which has always generated its image offset to the left. Last edited by SiriusHardware; 24th Oct 2022 at 8:59 pm. |
24th Oct 2022, 9:23 pm | #90 |
SiriusHardware
TV is a ALBA CTV 14RS, unfortunately no V-Height adjustment on the outside of the case. |
24th Oct 2022, 9:34 pm | #91 |
Not even available through a twiddle hole?
I tried looking for a service manual but it is a surprisingly obscure model, which was probably also badged by other low end badgers like Goodmans, etc. If we knew the chassis common to them all we would probably have more luck finding a service manual for that. Anyway, point proven, Invaders works great on original SOC hardware. |
24th Oct 2022, 10:20 pm | #92 | |
It would be easy to modify Invaders to use 1 or 2 less character rows so that it displays properly with the SoC design VDU cards. I’ll add that to the mods list. So it’s now been demonstrated on original SoC, Pi based, Ortonview and my VDU card That just leaves the replica SoC Module unless there are any others out there. |
24th Oct 2022, 11:05 pm | #93 |
The Czech replica of the SOC VDU is, like the Czech replica of the issue V MK14, virtually identical to the real thing. We don't know the whole story but we suspect that both PCBs were scanned from original SOC PCBs. The only identifiable difference between the Czech replica issue V and the real issue V is that the dome switch contact pads on the replica were laid out for four-point dome contacts where the original issue V used three-point contacts, this being a pragmatic adjustment because the person who made them found it easier to source four-point dome contacts.
So Tim's Czech replica of the SOC VDU is to all intents and purposes a real SOC PCB with the same track layout and circuit. The one thing which might make a difference is the character generator, as I think a slightly different version of the original character generator was supplied with those Czech kits. Even so, I don't think I have ever noticed anything different about the output produced by Tim's replica SOC VDU. So far Invaders has been tested with: Your (Realtime's) CPLD based SOC VDU emulator. Karen Orton's 'Ortonview' (built on a PCB designed by Sothie). Coolsnaz2's Pi + Dual port RAM based SOC VDU emulator. Coolsnaz2's original issue V MK14 + original SOC VDU + Homebrew RAM P.S - no need to modify Invaders because of the height problem, Coolsnaz2's TV is overscanning by a considerable margin. Look again at the shot from my CRT screen in post #63 - no problem with the height there, you can see a faint reflection of the top line of text on the bezel running around the top of the screen. Last edited by SiriusHardware; 24th Oct 2022 at 11:12 pm. |
25th Oct 2022, 9:26 pm | #94 |
One more to add to the diverse range of configurations with which invaders has been tested:-
Code:
'Slothie' MK14 'issue VI' (@4.00MHz) + Homebrew 0200-07FF RAM + Real SOC VDU. Apologies for the characters being slightly blown out on the image, I had the brightness a little on the high side. Note the image does fit on my CRT screen but I always have the height / width adjusted so that there is not much more than 1cm overscan all round. (screen is 14"). Also notice the image is offset to the left - that is normal for the SOC VDU, and illustrates one way in which both Ortonview and Realtime's CPLD VDU improve over the original. Do you have an official name for yours by the way, Realtime? 'Realview' springs to mind, but maybe you have already decided on something else. |
25th Oct 2022, 9:53 pm | #95 |
When I get five perhaps after Cambridge I will mod the code / or my wiring on my replica SOC card - it is identical as I also have the same few dots on the left and the missing top row on most TV's as CoolSnaz gets - My CRT's don't have vertical position either...
You are correct it was a compatible char gen supplied but, I have since provided a replacement original chip. |
25th Oct 2022, 9:54 pm | #96 |
Hmm, why, was there something awry about the supplied chip?
25th Oct 2022, 10:03 pm | #97 |
No he had just found stock of DM86S64CAB which looked identical - here are the pictures I posted in the thread to show the two side by side. Original on the right. [EDIT: as in original chip not the S64CAB supplied with PCB]
It was purely me trying to be totally accurate - then I went and patched in the per character inverse board that uses one of the unused bits... Last edited by Timbucus; 25th Oct 2022 at 10:16 pm. |
26th Oct 2022, 2:43 pm | #98 |
It hadn't occurred to me to name it, but I think Realview is a great suggestion. I'd be more than happy with that.
26th Oct 2022, 4:42 pm | #99 |
It was just to save us from having to write out 'Realtime's CPLD based MK14 VDU emulator' every time we refer to it, but actually, I have just Googled the term 'Realview' and it already generates a few hits. Maybe you would like to pick your own name for it which is unique as far as the internet is concerned, so if anyone goes searching for it with a view to buying one from you, they don't get led off down loads of dead ends.
29th Oct 2022, 3:54 pm | #100 |
I was listing some of the features of 'Realview' for ScottishColin and thought it would be good to do that here, now that the design is finalised.
The photo shows 'Realview' fitted with the DM8678 emulator (and there's a tape interface module in the foreground that also has the expansion RAM fitted). |
