16th Dec 2018, 9:02 pm | #1 |
C-MOS LOGIC Probe
Hi Guys, My Signal tracer Kit K7000 is now working, thanks to you Guys.
I came across this C-MOS LOGIC Probe in a car boot sale and was wondering if I could use it in conjunction with my Signal tracer, or do I use the probe separately? |
16th Dec 2018, 9:09 pm | #2 |
Re: C-MOS LOGIC Probe
A logic probe won't be much use for working on vintage radios.
It's designed for fault finding on logic circuits such as those found in synthesized signal generators etc.
30th Dec 2018, 7:12 pm | #3 |
Thanks Graham
31st Dec 2018, 11:29 am | #4 |
I would add to Graham's comments that it is designed for use on circuits working on about 15 volts or less. If you put a valve radio's HT supply across any connections to the probe, it will destroy the probe circuitry immediately.
Its a useful tool if you decide to have a dabble with digital circuits. Best to hang on to it, and read up on it. There is loads of info on the 'net on these probes, and they can be very useful. You may find yourself needing to use one one day. Tony. |
31st Dec 2018, 12:33 pm | #5 |
R-S sold them there are 2 types
1) TTL type (5 volt) 2) CMOS type 12 volt (or so) i have one of each |
31st Dec 2018, 2:09 pm | #6 |
They also had a switchable version for TTL and CMOS, it also had a pulse detector with a memory function, I sold mine earlier this year.
Peter |
