16th Dec 2015, 3:48 pm | #1 |
Dynatron ‘Nomad’ TP11
This Radio cost me a mere £3.00 and would like to restore it, but does anyone know how to remove the front Speaker grille on it.
I have looked inside for any fixings but non are apparent. I need to remove the speaker fret and brass surround as it badly dented. I downloaded the Service Data from Paul Stennings web site, which unfortunately doesn‘t say how to remove the speaker surround from the front of the cabinet. Paul. |
16th Dec 2015, 5:13 pm | #2 |
Re: Dynatron ‘Nomad’ TP11
Paul, have you tried inserting a butter knife (old fashioned dinner knife) under the edge of the brass surround and gently levering it up? And those four speaker studs, do you think they are attached to front grille or surround, or they the more normal Hacker reverse threaded ones as used on later Sovereigns? Nice looking set though.
16th Dec 2015, 6:09 pm | #3 |
Steve, Tried the ‘Butter knife’ approach and got it off the quick and dirty way!
It would appear that this was stuck on using a groove in the wooden front of the set, and a wood fillet went the circumference of the groove, in which the rear of the brass escutcheon sat. Now to try and refit it, looks like I am going to have to remove the old wood filling piece and make up some card soaked in super glue for added strength, and I thought this was going to be easy. Paul. |
17th Dec 2015, 8:18 am | #4 |
I don't think that you have to ensure the same level of strength as the original wood fillet when replacing the grille and surround. Like you say, a thick piece of card soaked in superglue will act as a 'locator' while you refit it using a Uhu type glue. Removing the old wood strip from the cabinet and the metal surround could be painstaking though, then on the other hand it may just flip out easily with an awl, we'll see. Keep us posted!
