Old 11th Feb 2018, 11:19 am   #1
Markone
Default GEC SA9083 Tester (ex BT)
Good morning, my first post here!
I am looking for some information on my SA9083 tester. I have had it several years just using the ohms ranges. This all works fine, as does the M Ohms range. It will not however measure voltage on the 5V DC range, or the AC250V (Off) setting.
I suspect an open circuit resistor or diode somewhere as I cannot measure any internal resistance through the meter terminals on these settings.
Can the circuit diagram be purchased for this meter? If I knew the rotary switch connections it would help me to trace the circuit. I can't find any fuses inside.
It was made around 1990 by GEC measurements (SEI) and is the version with the 9V battery.
Thanks in advance.
Mark.
Markone is offline
Old 18th Feb 2018, 10:13 am   #2
sortedradio
sortedradio's Avatar
Default Re: GEC SA9083 Tester (ex BT)
Hi Mark,
I believe the information you need is available FOC from https://elektrotanya.com/robin-teste.../download.html
Martin
BVWS member
GQRP Club
sortedradio is online now
