Old 26th Jan 2018, 1:28 pm   #1
linescan87
linescan87's Avatar
Default Samwell & Hutton Television Wobbulator 41B
Just thought I'd share this with you, recently found in a damp shed with some other stuff.
I let it dry out for a week and wound it up on the variac. Managed to get a trace on it. Will clearly need a bit of work but looks hopeful.
Cheers,
John Joe.
ID:	156168   Click image for larger version
linescan87 is offline
Old 26th Jan 2018, 2:41 pm   #2
Wendymott
Wendymott's Avatar
Default Re: Samwell & Hutton Television Wobbulator 41B
I am not suprised... Occasionally I used to travel to Eire on business.... (TV trade)..and I often thought that it could be a "hot bed" of antique electronic stuff....As most will know, Ireland is mostly rural, where a TV call out from Dublin could take all day just travelling to the customer and back, and if the set needed to go to the workshop, "double bubble".
I had to visit a repair agent in "3 Castles" south of Dublin, his workshop was in a barn, in the middle of nowhere.. To find the place, I stopped at a TV shop on the outskirts of Dublin..."never heard of it" says the guy..... it was only by chance I found it another 10 miles further on...Thus I can imaging, lots of "barns" with stuff...... that you dont get with city/town dwelling.
Should get out more.
Regards
Wendy G8BZY
Wendymott is offline
Old 26th Jan 2018, 3:02 pm   #3
M0FYA Andy
Is that the same type that I asked about here a few months ago? Mine didn't come with the Band 3 Adaptor, though.
Andy
M0FYA Andy is offline
Old 26th Jan 2018, 3:50 pm   #4
linescan87
linescan87's Avatar
Hi Wendy,
Don't know about Ireland being a hot bed of vintage electronics!!
Andy I seen your post, it certainly looks similar.
Cheers.
Old 26th Jan 2018, 4:48 pm   #5
M0FYA Andy
I just dug out the pictures of mine, it looks very similar, but yours has more controls so not the same model.
Andy
Old 26th Jan 2018, 5:24 pm   #6
kan_turk
kan_turk's Avatar
This brings back memories - had one myself, complete with B3 adapter - bought on Tottenham Ct Rd, London about 1971 - brought it home after a stint in Britain - and had it for a few years up to c 1986 - it worked fine once I got the hang of it
Rgds
John
kan_turk is offline
Old 29th Jan 2018, 1:47 pm   #7
AndyGilham
Little bit of trivia, Samwell and Hutton movements were designed and supplied by Avo during the 50's and 60's
AndyGilham is offline
Old 17th Feb 2018, 2:03 pm   #8
Vintage Engr
I used one of these when I worked for Rediffusion in the 1960's. Great piece of kit once you get used to its quirks. ( The sweep can run backwards!).
I also used to go to the manufacturers in Goodmayes, Essex, for spare parts & etc.
Brings back a lot of memories. We had a number of field engineers that used to 'twiddle' IF's for no other reason than a bit of low gain, that would have been solved by valve replacement. It got so bad, that one night when I came off shift, I had a plan. The engineers used to hang up their white coats (yes, we had to look smart) & leave their trimming tools in their top pockets. So I went round & cut all the hex ends off them with wire cutters! The Sam Hutton was in regular daily use. There were quite a number of ex-govt parts used in their manufacture.
Have fun with it.
David.
Vintage Engr is offline
