Old 25th Jan 2018, 9:43 pm   #1
Richard_FM
Richard_FM's Avatar
Default Heating Bulbs
When my Mum was a student some 50 years ago one of her fellow students had a high powered lightbulb of I'm guessing 150-200 watts.
This was a way to heat his room while taking advantage the "no charge for lighting" rule.
Their landlady confiscated it a few times when he left it in the fitting in his room!
Richard_FM is offline
Old 25th Jan 2018, 9:49 pm   #2
duncanlowe
Default Re: Heating Bulbs
They are still remarkably common as the heaters in American hotel bathrooms, but with a clockwork timer so you don't leave it on. Hateful things / places.
duncanlowe is offline
Old 25th Jan 2018, 9:54 pm   #3
russell_w_b
russell_w_b's Avatar
Like an incubator lamp? We used them to keep the mercury vapourised in the 26kV HT ignitron crowbars on the Marconi B6126 300kW HF transmitters at Skelton.
I remember when I was a kid, my mam had one of those infra-red 'heat lamps'. I recall it having a three-pronged bayonet connection so it wouldn't fit anywhere else. It had red glass though, so no good for lighting.
Regds,
Russell W. B.
G4YLI.
russell_w_b is offline
Old 25th Jan 2018, 10:10 pm   #4
G6Tanuki
G6Tanuki's Avatar
Still widely used in the agricultural and veterinary worlds, as a way to provide warmth to lambs/calves/chicks/kittens/puppies.
Random example: http://www.tannertrading.co.uk/lambi...t-lamps-bulbs/
I also remember from my student-digs days the "bathroom lamp" fitments which had a 100W bulb in a 'globe' in the centre and a 500-750W heater [coiled element inside a ceramic tube] round the outside, with a pull-cord that controlled both.
One pull - light. Two pulls - light and heat.
Yes, they ran off a 5-amp fused lighting circuit.
G6Tanuki is offline
Old 25th Jan 2018, 10:14 pm   #5
dglcomp
My gran still has one of them or something similar in her kitchen will get pictures when I'm next there, not used now she has central heating but no point in replacing esp. as it has a normal light switch anyway and it just get left on 'light'.
dglcomp is offline
Old 25th Jan 2018, 10:36 pm   #6
dseymo1
The red ones are of course can still commonly be found in the Philips Infraphil and similar therapeutic lamps. I have one which I use for drying paint and such.
My grandmother had one of the bathroom fittings - a 'luxury' version with two 250W lamps, all suspended from a standard BC batten holder.
dseymo1 is offline
Old 25th Jan 2018, 10:47 pm   #7
McMurdo
McMurdo's Avatar
our local car bodyshop uses infrared lamps for drying paint.
My mum had the philips infrared heat lamp for her bad back, in a swivel stand. I once saw it on the coffee table and went over to play with it, not realizing she'd just had it on, and it was still hot.
Anyone who's slid a teatray along a self-serve cafe will have seen them over the pies!
We had the white-light ones for the chicks at home.
You can also get black-heat lamps that dont give out any light but look like a par lamp. I built a few devices for a breeder of fancy hens which would detect the current in the heat lamps and switch from a main to a backup if the main lamp stopped taking current, and put on a warning light in the henhouse. If the lamps blow in the night you wake up to a flock of dead chicks.
Kevin
McMurdo is offline
Old 25th Jan 2018, 11:00 pm   #8
paulsherwin
paulsherwin's Avatar
I built a home made heated propagator using a 15W pygmy bulb for heat. It has a switched series diode to reduce the heat output on warm days. Germinates the tomato seeds a treat
paulsherwin is offline
Old 25th Jan 2018, 11:12 pm   #9
julie_m
A house I used to live in had one of those bathroom heaters. Even with 750 watts for the heater and 60 for the light, it would leave 390 watts available with a 5A fuse or MCB.
julie_m is offline
Old 26th Jan 2018, 12:39 am   #10
emeritus
I got one of those bathroom lamps from Argos for my late mother in the early 1970's , but the heater got little use once the council had installed central heating some 20 years later. As supplied it had 4 switching actions on consecutive pulls: off; light on; heat and light on; heat on; and back to off. After a number of occurrences of the heater having been left on inadvertently, I rewired the switch so that the original LIGHT contacts were connected directly to the looped lighting circuit and controlled the heater, the light being connected to the original bathroom switch.
emeritus is offline
Old 26th Jan 2018, 2:11 am   #11
Boater Sam
To prevent the water points freezing on our moorings I installed a 60w BC lamp in a tin can, controlled by a 5 degree stat and a fuse in every cubicle, so far it has worked.
We used PAR lamps for paint drying in the body shop, an advantage is that you can see even the smallest blemish with that much light.
Boater Sam is online now
Old 26th Jan 2018, 7:39 am   #12
broadgage
I still use an E27 300 watt clear heat lamp in my bathroom, they are less popular than in the past but replacements are readily available.
I have also a 100 watt red version suspended over the cat basket. Cats enjoy warmth, especially radiant warmth. It is lit each night on a time switch so as to make best use of off peak electricity, and to provide comfort for the cat without making him over dependant on artificial heat.
If going out all day in cold weather and therefore not lighting the wood burning stove, then I leave the infra red lamp on all day.
broadgage is offline
Old 26th Jan 2018, 10:09 am   #13
Brigham
The 75 watt carbon filament lamps I use at home and at work are from an agricultural supplier, and are packed in cardboard rolls marked 'carbon heater'.
They are indistinguishable from the later-type carbon bulbs, the sort with the pip inside the cap.
Brigham is offline
Old 26th Jan 2018, 10:53 am   #14
peter_scott
peter_scott's Avatar
There are also the types used in early electric fires.
http://lowres-picturecabinet.com.s3-...n/21/99874.jpg
Peter
peter_scott is offline
Old 26th Jan 2018, 3:06 pm   #15
Rubberfingers
Pictures please, for all the cat lovers on this forum!
Rubberfingers is offline
Old 26th Jan 2018, 6:46 pm   #16
Paul_RK
Paul_RK's Avatar
I seem to remember a yellow moulded casing suspended from my grandmother's bathroom celing with two heat lamps side by side - I should remember it, I saw it often enough as up to age 13 I visited every Sunday afternoon for a bath. Strange I've not thought of seeking something similar in the 24 years we've lived here with an unheated bathroom.
Paul
Paul_RK is online now
Old 26th Jan 2018, 7:33 pm   #17
duncanlowe
Another vote for 'my Mother in Law had one of those in the bathroom'. Replaced many years ago (before part P) with a standard light, and a separate down flow fan heater from a new supply.
Old 26th Jan 2018, 7:46 pm   #18
Bazz4CQJ
Bazz4CQJ's Avatar
Several types of lamps have been referred to; I'm not sure whether any of them are the same / similar to the Quartzray lamps offered by Dimplex https://www.dimplex.co.uk/product/qx...-quartz-heater
IIRC, these came on the scene with some fanfare in the mid-1990's, sold on the the "warm the people not the air" theme. I have two 1600W lamps which I used to use in a small workshop. They definitely kept me warm; never totally sure of the economics of buying (pricey) and using?
B
Bazz4CQJ is online now
Old 26th Jan 2018, 7:48 pm   #19
G6Tanuki
G6Tanuki's Avatar
Some years back I made a Biltong-machine for a South African friend. I used two 60-Watt incandescent bulbs in series as the heater.
What's a Biltong-machine I hear you ask? See https://www.sa-austin.com/make-biltong-box.html
G6Tanuki is offline
Old 26th Jan 2018, 8:31 pm   #20
dglcomp
A local ex-Church has a load of these, un-used but still in place. In the electrical cupboard there is a fuse box about 3ftx1.5ft just for the heating (well most of it!) with many 16A or maybe 13A breakers on different phases.
It's all controlled by a large 3ph contactor (plus another smaller one that only controls ~6-9kW), so despite the high power only one small switch to turn it all on.
dglcomp is offline
