Old 26th Dec 2017, 6:16 pm   #1
Sinewave
Sinewave's Avatar
Default Avometer 8 Mk4 repair and restoration
Some time ago I acquired a Universal Avometer Eight, Mark 4. Unfortunately it didn't work at all.
Every so often when I had time I pulled out the drawings and followed the circuits to try and find what was stopping it from working. As it were completely non operational, I was rather hoping of some common fault which would be quite obvious to find.
But, I couldn't find a fault, so that then took me to look at the movement. So I removed the movement from the meter to take a good look and make some checks. I connected my loop calibrator to it to supply the 37.5 micro amps to see the needle move the full scale deflection.
And much to my surprise, the movement works. I needs a few more micro amps to get the full scale deflection, so perhaps the magnetic shunt needs adjusting, but this is something I haven't done yet.
I then placed the movement back, connected everything up and thought I'd have another go at tracing the fault and much to my surprise the entire meter is working again. So perhaps I'd disturbed a poor connection on the reverse moving coil switch when disconnecting the movement from it.
I have mentioned this in another thread which was really for something different, so I thought I'd make this thread so that we can go into more detail and get more out of this.
I'd like to bring the accuracy of the meter back into specification, so I'll need to find what I should be adjusting. But before that I need to see if it's out of calibration on all ranges or if it's only certain functions and ranges, by making cal checks on all ranges.
ID:	154453   Click image for larger version
ID:	154454   Click image for larger version
ID:	154455   Click image for larger version
ID:	154456   Click image for larger version
Avometer, vintage Fluke and Marconi collector. Also interested in vintage Yaesu and KW.
Sinewave is offline
Old 26th Dec 2017, 6:21 pm   #2
Default Re: Avometer 8 Mk4 repair and restoration
Ah, it's only 5% out, good enough for most (all?) repair work.
Old 26th Dec 2017, 9:04 pm   #3
The Philpott
The Philpott's Avatar
One possibility that comes to mind regarding the actual meter movement:
If the insulation between the layers of wound wire has become corrupted, a short may have occurred between 2 sections of wire in different layers.. the designated current for FSD would not generate the required deflection as the current would be effectively flowing through a shorter coil than intended. If for example the current was running through a wire 'path' of 19 inches instead of 20 inches the deflection would fall short. (I hope this makes sense)
The Philpott is offline
Old 27th Dec 2017, 8:38 pm   #4
Sinewave
Sinewave's Avatar
Well, that's on this FSD test, but I really need to see how linear the inaccuracy is to see if it's across all ranges.
Yes that makes sense, but I hope it's not the case with this one. If it doesn't go faulty again, then hopefully it's alright.
Sinewave is offline
Old 28th Dec 2017, 10:07 am   #5
Phil G4SPZ
Phil G4SPZ's Avatar
I think the first thing you should try is adjusting the magnetic shunt to see if you can get 37.5uA to generate a full-scale deflection. If not, the magnet may have lost strength - Dave has tried adding tiny neodymium magnets to boost a tired main magnet.
Do check the basics like hairsprings and zeroing first.
Phil
Phil G4SPZ is offline
Old 28th Dec 2017, 12:00 pm   #6
Jon_G4MDC
Jon_G4MDC's Avatar
One of my 8s had a magnet that lost it's voodoo.
Even without the shunt it was under reading by 20%.
With nothing to lose I wound a solenoid of 16SWG enamelled wire (I forget how many turns perhaps 20?) and zapped it with a 12V car battery. Just a glancing swipe with the end of the wire on the +ve terminal.
After that I had a movement which read 20% the other way! Today it has the full shunt and an additional magnetic bypass on it and it works well enough.
Jon_G4MDC is online now
Old 28th Dec 2017, 8:07 pm   #7
Sinewave
Sinewave's Avatar
Has anyone had any luck with 'magnetizers' to re magnetize the magnets?
Sinewave is offline
Old 28th Dec 2017, 9:50 pm   #8
The Philpott
As Phil says, the magnetic shunt may be able to compensate (for some inexplicable reason I thought you had already tried this- I blame Christmas booze for this unfounded assumption)
The later shunts I have tweaked on a Mod 8/III are razor blade shaped, secured by a screw and spring washer, and quite a small change in position gives a significant amount of compensation. I imagine the later Mod 8 units are similar.. The earlier meters with the horseshoe magnets have less scope for adjustment. As Phil mentions i managed to resolve an early meter with 7% shortfall totally outside the scope of the adjustment mechanism, by aralditing a neodymium magnet in a suitable place. I would think on a later meter you have better chance of success without resorting to this.
i don't personally know anyone who has tried remagnetising. Likely to be rather specialized due to the precision involved.
