Old 16th Jan 2018, 9:41 pm   #61
Station X
Station X's Avatar
Default Re: Exploding X2 capacitor
Originally Posted by Station X View Post
This evening I was using my ancient Singer electric sewing machine to repair my boiler suit. Suddenly the machine started racing and smoke came out of the foot pedal. I switched off at the wall socket, but not before it had done about six inches of unwanted stitching which will need to be unpicked.
On opening up the foot pedal, which is a very crude device, I found that a Rifa Class X Capacitor had exploded and in doing so gone short circuit. It was wired across the OFF/ON contacts which accounted for the machine not stopping when the pedal was released.
I snipped out the Rifa and all was well again. I'll replace it tomorrow.
Having replaced the Rifa, the bad news is that in "running away" the machine snapped several teeth off a plastic bevel gear. This upset the synchronisation and snapped the needle.
I have a new gear on order and fortunately have found a useful website showing how to replace it and resynchronise the machine.
Graham. Forum Moderator
Station X is online now
Old 16th Jan 2018, 10:49 pm   #62
Refugee
Refugee's Avatar
So that Rifa is guilty of killing a sewing machine. We need to call the capacitor police and get it jailed
Refugee is offline
Old 20th Jan 2018, 3:58 pm   #63
turretslug
turretslug's Avatar
Maybe I should hold off applying power to this NOS 3-phase filter/rectifier panel until November 5th.... All 9 Rifas are well cracked.
Name:	Finnish Firecracker.jpg
turretslug is offline
Old 20th Jan 2018, 4:01 pm   #64
Refugee
Refugee's Avatar
That looks like a jumping jack waiting to go off.
Refugee is offline
Old 20th Jan 2018, 4:05 pm   #65
MrBungle
MrBungle's Avatar
I'd turn it on outside!
MrBungle is offline
Old 20th Jan 2018, 4:07 pm   #66
Refugee
Refugee's Avatar
Defuse it first and save on cleaning the board.
Refugee is offline
Old 20th Jan 2018, 7:05 pm   #67
Philips210
Hi
The worst part of the saga has to be cleaning up the horrible mess that's often left on a PCB or whatever after the blow-up. Repacing the cap is the easy bit. That reminds me, I must check my Philips 'scope to see if it has one of the horrors installed.
Regards
Symon.
Philips210 is offline
Old 20th Jan 2018, 7:18 pm   #68
MrBungle
MrBungle's Avatar
It’s pretty difficult to get off isn’t it. I would check your Philips scope. I’ve had two Philips scopes blow one of these up on me now.
MrBungle is offline
Old 20th Jan 2018, 7:25 pm   #69
Philips210
Hi.
Yes, it's awkward removing the brown mess. Carefully scraping and wiping off as much as possible first before using a solvent soaked tissue or cotton bud. I've never really worked out the best thing to use for removing the mess. What is the best approach to cleaning the board etc?
Regards
Symon.
Old 20th Jan 2018, 7:31 pm   #70
MrBungle
MrBungle's Avatar
When one went off in my scope, I used IPA. I couldn’t completely clean it off if I’m honest so got the worst off mostly.
MrBungle is offline
Old 20th Jan 2018, 7:32 pm   #71
G6Tanuki
G6Tanuki's Avatar
I've found aerosol car brake-cleaner:
https://www.screwfix.com/p/holts-aer...er-600ml/1396g
to be rather good for removing the evidence.
[Also good for removing the sticky splurges when an old-style paper-waxie "mains decoupler" capacitor has let-go]
G6Tanuki is online now
Old 20th Jan 2018, 7:51 pm   #72
Philips210
Hi
I tried WD40 and IPA which works to an extent but I'll get hold of some of that brake cleaner which sounds to be useful.
Slightly OT but when removing the etch resist ink from a PCB after etching, I found by experiment that meths or white spirit on their own don't work well. If however they are mixed it seems to be quite good at removing the ink. What the reason for this is I don't know.
I am beginning to think the design of those caps is starting to show it's cracks.
Regards
Symon.
Old 20th Jan 2018, 7:59 pm   #73
MrBungle
MrBungle's Avatar
RS 99% IPA works nicely in etch resist. (Well marker which is what I use as etch resist anyway)
MrBungle is offline
Old 20th Jan 2018, 8:05 pm   #74
Philips210
Thanks for that. I must admit to not trying IPA for the task. When I've used enamel paint for large areas of etch resist then Nitromors does the trick. I'd better get back OT.
Regards
Symon
Old 20th Jan 2018, 11:14 pm   #75
Refugee
Refugee's Avatar
In my vacuum cleaner the air flow got rid of the worst of it.
I just needed to put the motor filter in hot water and washing up liquid.
Refugee is offline
Old 29th Jan 2018, 9:46 pm   #76
evingar
evingar's Avatar
Originally Posted by evingar View Post
Mine got replaced a few weeks ago - a mere youngster at 1999 vintage, but still had that "crazed" look about it - They often start looking crazy before they act accordingly
.... Following on from this, I mentioned to Mum (in her 80s') that hers might need checking. She replied that her Henry had actually filled the kitchen with smoke a few months back, but she left it outside to "cool off" and then continued to use it. That's the war child generation for you
On investigation, I of course found the usual foul smelling stick mess inside. !!
Chris
evingar is offline
Old 29th Jan 2018, 11:18 pm   #77
turretslug
turretslug's Avatar
One time, sorting out a Rifa-stricken appliance at my parents, Dad (an ex- military and civil pilot) said, "It was exactly the way Canberra cockpits used to smell"- apparently having experienced several electrical failures.
Old 29th Jan 2018, 11:50 pm   #78
Refugee
Refugee's Avatar
Well post#75 is our second Henry to have one go off in it (smiley for pooh).
Refugee is offline
