Old 11th Dec 2017, 3:14 pm   #1
Oldcodger
Default Solder suckers (AKA desoldering tools).
Often we see posts where it's only too easy to go OT offering ideas on making these work better. So here's what I've found in my years on the bench and in the field.
Solder suckers work best with lubrication and some form of heat resistant oil works wonders. In one factory, I worked in we found a tin of gun oil and tried it out on ours. These days I use WD 40 or similar.
As for the tip deforming with heat - stick a Hellerman sleeve on it. Better suction and if it burns - cut the burnt bit off.
Tip a bit slow to heat up- dip it in a pot of flux.
Add some solder + flux to the joint to get it flowing.
And if all fails, and it's a small board- heat the solder up and flick off the excess on a waste surface.
Oldcodger is offline
Old 11th Dec 2017, 8:20 pm   #2
m0cemdave
Default Re: Solder suckers (AKA desoldering tools).
Yes, an H30 sleeve over the PTFE nozzle is the classic method of improving the small hand-pump types.
It's also worth noting that Hellerman silicone oil is ideal for lubricating the workings of the sucker after a strip-down and cleaning session.
m0cemdave is offline
Old 11th Dec 2017, 8:49 pm   #3
The Philpott
The Philpott's Avatar
I must admit i used red rubber grease as i knew it wouldn't attack the seal. (Normally used in assembly of hydraulic brakes)
The Philpott is online now
Old 11th Dec 2017, 8:51 pm   #4
MrBungle
MrBungle's Avatar
I’ve entirely stopped using them now after about 20 years. Turns out lots of little blobs of solder make an appearance when you rearm it and then fall out on the board you are working on. This recently caused the magic smoke to come out of a TSSOP package for me. Took me a while to see it but a piece had actually got under the legs of the package.
Straight in the bin. Chemtronics wick only now.
MrBungle is offline
Old 11th Dec 2017, 9:14 pm   #5
Philips210
Hi.
I like the idea of the sleeve over the nozzle, I'll give that a try.
I use both desoldering pumps and decent desoldering braid. The pump can be problematic on boards with small soldered joints and the obvious risk of short circuits fron stray solder from the nozzle. If the pump is used at a suitable angle then the risk is minimised. In any case the board has a thorough inspection and a good brushing before the power is applied.
For old equipment with large soldered joints I mostly use the pump and in some cases further clean the pads with the braid. For more modern equipment it's mostly the braid that's used. It's really horses for courses, so use both methods according to the job in hand.
Regards
Symon.
Philips210 is offline
Old 11th Dec 2017, 9:47 pm   #6
Bazz4CQJ
Bazz4CQJ's Avatar
I'm always surprised that the suckers work as well as they do. I've never used a lubricant in one; is it possible that it will get bits of solder sticking to it which could impair the seal - hard to say, so worth trying.
The braid is wonderful... when it's new. I think someone on here recently suggested that the Servisol braid has a better than average lifespan?
B
Bazz4CQJ is offline
Old 11th Dec 2017, 10:04 pm   #7
MrBungle
MrBungle's Avatar
Chemtronics stuff lasts a long time. I keep it in a zip lock bag:
https://uk.rs-online.com/web/p/desol...raids/7630709/
Comedy packaging you will find if you order it from RS. It usually comes in a massive cardboard box with a thick wodge of hazardous materials documentation.
MrBungle is offline
Old 11th Dec 2017, 10:29 pm   #8
McMurdo
McMurdo's Avatar
My old AB /abeco solder sucker (RS green one) is rarely used these days. I wore my original one out, and after finding they dont do spare parts for them, bought a new one from RS, it dodnt work, had it replaced under warranty, that didnt work either, then another, then gave up. The tips didn't last, the springs broke, the little push buttons wore away and the central ejector pin used to get coated in solder that could only be melted off with a blowtorch. I discovered the design had been bought by a company in Malta.
Now I use a cheap CPC vacuum desolder station. It's streets ahead and doesn't fetch tracks off.
Kevin
McMurdo is offline
Old 11th Dec 2017, 11:05 pm   #9
Station X
Station X's Avatar
On vintage consumer equipment PCB's with wide tracks, I melt the solder with an ordinary iron then blow it away with a jet of compressed air, which has the advantage of cooling things down.
I've been warned that the displaced solder will form conductive bridges all other the place. This doesn't seem to happen though. The solder kind of granulates and is easily brushed off with an old tooth brush.
Graham. Forum Moderator
Station X is online now
Old 11th Dec 2017, 11:28 pm   #10
The Philpott
My cheap one is badged as Silverline, which means it could originate pretty much anywhere in the world. It's OK bearing in mind the price.
Old 12th Dec 2017, 12:25 am   #11
paulsherwin
paulsherwin's Avatar
I do this sometimes as well, but I blow the air through an old ballpoint pen case held in the mouth. You do have to be careful to clean up afterwards though, as you can cause bridged tracks.
paulsherwin is online now
Old 12th Dec 2017, 12:30 am   #12
Bazz4CQJ
Bazz4CQJ's Avatar
Maybe a syringe might be worth a try as a blowing tool? Probably need some heat-shrink on the tip to stop melting.
B
Bazz4CQJ is offline
Old 12th Dec 2017, 8:18 am   #13
Diabolical Artificer
Diabolical Artificer's Avatar
On my cheapy the nozzle gets blocked with solder which needs un-blocking by pushing a rat tailed file down it; it works ok though.
I have a heated one, cheap ebay jobbie, which is good for de capping PCB's and other big stuff, though the tip gets very hot.
I've found braid sometimes needs a lot of heat and is a bit fiddly.
For tag board I heat the solder up with an iron and a sharp tap on the edge of the bench gets rid of excess solder. Component leads can then be unwound with the joint cold. I don't wrap the new component leads round the tags, just a 90 degree bend does the job.
Andy.
Old 12th Dec 2017, 9:36 am   #14
Herald1360
Herald1360's Avatar
Get one of those flux felt tip pens. Run a few inches of old wick (or any copper braid) under the tip and it works like new.
....__________
....|____||__|__\_____
.=.| _---\__|__|_---_|.
.........O..Chris....O
Herald1360 is offline
Old 12th Dec 2017, 1:08 pm   #15
Oldcodger
Still using the two I "acquired" . One I know is from GEC and it's possibly 80's in origin. I still empty mine into a bin after every operation as per a tip I learned from the reworkers at MSDS.
Old 12th Dec 2017, 2:32 pm   #16
Boom
I take the heavy stuff off with a sucker but for unsoldering through holes I find that old co-ax outter screen dipped in flux can't be beaten and is far cheaper than commercial desoldering wick.
Boom is offline
Old 12th Dec 2017, 3:14 pm   #17
AC/HL
AC/HL's Avatar
As with most things, the right tool for the job in hand.
AC/HL is offline
Old 12th Dec 2017, 8:35 pm   #18
Oldcodger
What was prefered in MSDS (Clansman RT 353 production) was slimline coax sheath dipped in flux.
Old 13th Dec 2017, 7:37 pm   #19
Philips210
Hi
CPC are usually good at comedy packaging as we know!
Their cheap aluminium desoldering pump http://cpc.farnell.com/duratool/zd-1...ing/dp/SD01154 works surprisingly well and is easy to dismantle for cleaning. They're so cheap I keep a few in stock.
I also found the green aluminium RS pump to be poor compared to the one I used back in the 1980's. The new one blocked far too easily for my liking even on quite small soldered joints. There is a subtle difference in appearance between the two pumps. I'll try to find them and check the differences.
Regards
Symon.
