23rd Jul 2013, 1:15 pm | #1 |
Pye M201 Microphone Help
I recently inherited a Pye M201 Radiotelephone which I want to use as an airband radio station for an airfield (read as long bit of grass!). I've managed to get it working and can receive transmissions but I don't have a microphone. There's a picture of the back of the machine here:
[img]http://farm8.*****************/7452/9351435560_c313529e64.jpg[/img] I have all the relevant qualifications/licences to use it but need some help sourcing a microphone. Can anyone help me please? |
23rd Jul 2013, 2:27 pm | #2 |
Re: Pye M201 Microphone Help
I reckon you'll find the M201 is *well* past its CAA type-approval period for any kind of UK airband use.
They're certainly no longer type-approved for private-mobile-radio use (and haven't been for at least the last fifteen years). |
23rd Jul 2013, 2:32 pm | #3 |
Actually I've had it certified for use and have approval from the CAA. Just need to know what mic I need, can you help?
23rd Jul 2013, 2:47 pm | #4 |
As far as I know the microphone from any Pye mobile will work, certainly the earlier ones.
23rd Jul 2013, 2:55 pm | #5 |
I have one and have sent you a PM with my number to call later.
23rd Jul 2013, 3:08 pm | #6 | |
The microphone usually used with the Olympic series radios (and also with some of the military 'MOULD' stuff I had a lot of experience on) was nicknamed the "shaver" microphone because it has an angled head with a silver grille on the end which looks rather like an electric shaver. It has a bright orange PTT button, and uses a 3-terminal Electret insert which needs a +10V supply from the radio to operate. http://highfields-arc.co.uk/construc...cpye/pye03.htm Note that some of these mics have a timer circuit built into the microphone that limits the PTT operation to something like a minute - after this it reverts to receive even if you have the PTT button pressed - the idea being to stop the channel being jammed if someone sits on the PTT. Hope that helps. --G6Tanuki |
23rd Jul 2013, 3:48 pm | #7 |
There is a conventional type microphone as well as the shaver version. Usually there is
a small label on the cable indicating FM or AM, the latter usually has an extra capacitor as a low pass filter. Pye became Philips RCS became Simoco so other brand labels may work. |
23rd Jul 2013, 4:24 pm | #8 |
Thank you all, especially gohunter. Managed to sort this out and should have it all working in a few days. I found a letter from the CAA along the lines of "that's really old but if you get it tested then I guess that's OK". Luckily I managed to find the follow up letter granting approval!
I'm amazed that this was sorted out in a few hours, what a great forum! |
23rd Jul 2013, 4:43 pm | #9 |
Just as a follow up, I've checked Chris Lorek's book and it gives the connections as:
1. Mic 2. Screen 3. PTT 4. Earphone 5. PTT |
