28th Jun 2013, 6:44 pm | #1 |
When capacitors go bad.
My new "dabble when I'm not busy" toy is a 1950s marine radio [RX has 12-volt-HT valves and a big single-ended class-A transistor for audio output, EF89/6L6/6L6 on the RF side, vibrator and two EZ81s for the HT].
So far I've got the RX to make noises - though both the aerial-coupling windings on the front-end have clearly been used to pass some significant current and are now open-circuit hence the poor thing is as deaf as a deaf thing. Experimental rewinding is clearly needed. The transmitter - well, I've spotted a major "ooh nasty" - here's the pair of capacitors used to resonate the secondary of the vibrator-transformer: one capacitor has entirely shed its outer casing, the other is split and there's molten wax all over it. |
28th Jun 2013, 8:29 pm | #2 | |
Re: When capacitors go bad.
Mark |
28th Jun 2013, 8:43 pm | #3 |
Ah, that looks to be a lovely example of the genre "Noise-Emitting Capacitor".
[Not to be confused with that other device - rather rarely encountered today - the Smell-Emitting Diode]. |
28th Jun 2013, 11:06 pm | #4 |
Your capacitor shed its encapsulation but the wound element stayed in place. This one in an Abbey tape deck did the opposite - the cardboard tube remained attached to the leadout but the capacitor itself shot out of the end. A capacitor-emitting capacitor.
Lucien |
28th Jun 2013, 11:25 pm | #5 |
Try a main smoothing cap (bomb) going off in a new Thorn 950 series TV back in the seventies in the DER showroom, Silver Street, Doncaster where I worked. That's a real bang.
PS. It spilt the wooden cabinet.
28th Jun 2013, 11:28 pm | #6 |
I think it's something they do to distribute seeds and reproduce.
29th Jun 2013, 7:01 pm | #7 | |
I just did a test of the 'exposed' capacitor shown in my first posting: hooked it across a 450VDC supply and it passed around 35mA - enough for it to get painfully hot after ten seconds! |
29th Jun 2013, 7:36 pm | #8 |
The wax French are the best as when they overheat through leakage, it's very easy to pull out the guts and restuff.
29th Jun 2013, 7:45 pm | #9 | |
A friend some time back was rebuilding an old radio and automatically went through it replacing all the apparently-old-and-suspect capacitors with modern Polyester beasties. Some weeks later he met the radio's previous-owner-but-one who told him "I patiently restuffed all those!". The radio in question continues to work. There's a "Zen" metaphor in there somewhere I'm sure. |
29th Jun 2013, 9:17 pm | #10 |
I do restuffing on some sets. I leave a note inside the set to say what's been done.
29th Jun 2013, 9:42 pm | #11 |
Don't do much restuffing on sets through the workshop but there again do not get many French ones'.So in the main G6T you are correct.
Though Graham is also right to leave a note inside.
28th Aug 2013, 6:40 pm | #12 |
I've had endless fun replacing all the small tantalum caps in some 1980's test-gear which worked fine until put into unheated storage over a very cold winter. A touch of frost did them a power of no good.
Trev |
28th Aug 2013, 7:56 pm | #13 | |
We had many different variants of early colour TV's on long term & accelerated soak testing all on a 24 hour non stop cycle. Eventually we became imune to jumping out of our skins when caps used to explode, sometimes several sets in short rotation. Then, as a junior, my job was to remove the offending cap/s & debri, fill out a technical sheet to record various data about the item/s and pass it on to the Technical Evaluation department. Working in there was a nightmare, not because of exploding caps but also the high temperature of the unit & more so because of the static build up. Once we were given a "VSP" (Very Special Person) set to give a thorough soak test to and after replacing a few faulty parts during it's soak test period, the set was passed to the cabinet fitting section. A hand made, solid teak cabinet was fitted & Sir Jules personally delivered it to 'Buck House'. Six weeks later a very burned & smoke blackened set was returned back ! Whoops!
When I die, please don't let my Wife sell my collection for the amount I told her I paid for it! |
