14th Sep 2022, 4:26 pm | #1 |
AVO VCM163 problem.
Was going through the Service manual "setting up procedure"after installing a replacement mA/V meter when reaching (k) in"setting up procedure" I only got a reading of 24V dc not the expected 52V dc. Was wondering if there is an obvious reason for this.
16th Sep 2022, 9:12 pm | #2 |
Re: AVO VCM163 problem.
The most obvious answer is that you're measuring at the wrong end of R21
John |
18th Sep 2022, 5:38 pm | #3 |
How right you are. Did eventually realise what I was doing wrong.
My problem at the moment is not being able to calibrate to the red CAL line(always too high) on the mA/V meter when going through the process of setting up and calibrating. |
