24th Jan 2016, 8:32 pm | #41 |
Re: 1930's (?) GM Frigidaire
that looks surprisingly modern for the exterior style of the fridge. The last vintage fridge I looked into the back-of was a hotpoint and it had something that looked like it could inflate tyres.
Kevin |
24th Jan 2016, 11:20 pm | #42 |
No, it won't make a noise if it's leaking.
The system is already under pressure, about 80 psi at room temperature (if there's any gas in it). It's a pity that you can't attach a manifold gauge set to see what is happening when the system is running, without knowing the pressures is like trying to see if a current is flowing in a circuit without having a meter. When you do get it fired up, the first indication that it may be doing something useful is the condenser (radiator thing at the front) will get quite hot after a couple of minutes running. Andrew |
25th Jan 2016, 8:37 am | #43 | |
Perhaps paying for the time of a refrigeration engineer to check it out beforehand would be a wise move. Many thanks, Darren.
Perfection is the enemy of the good... |
25th Jan 2016, 9:51 am | #44 |
I certainly woulden`t run the compressor up on reduced volts, the starter winding could just burn out without their being enough "grunt" to spin the motor against load.
25th Jan 2016, 10:30 am | #45 |
In a ventilated space, the amount of R12 in the system will not do you any harm whilst you run it up, if it is leaky it will already be gone.
Don't run it on reduced voltage, it is a relay start motor and it will burn out. Run it with a fuse in the plug, 10 or 13A as the start current is quite high, for 10 minutes or so. If the condenser on the back gets warm and the evaporator in the ice box gets cold, you have a working fridge. These were very reliable units, don't run it if you have moved it in the last 2 hours. Most modern units run on Propane mix as gas charge and will not work if kept at cold temperatures as in garages etc. Such is progress. You should be able to fit a universal door seal kit, superglue to assemble. |
25th Jan 2016, 2:03 pm | #46 |
I didn't realise it was a sealed unit, didn't think they made them that long ago.
Peter |
25th Jan 2016, 5:16 pm | #47 |
I have to say that I expected to see a "separate" motor/pump unit, stiil, it has 3 chances...
1. BANG and the RCD trips. 2. Runs but doesn't get cold. 3. Purrs quite happily and does what it says on the box. I remember as a "yoof" that when I had built a project/repaired something I used to plug it all in, ready switched ON and then push the socket switch to ON with a garden cane. Life's like a box of chocolates. Andrew |
25th Jan 2016, 6:09 pm | #48 |
Thank you all for your advice, i'm going to fire her up this week based on your suggestions - I especially like the garden cane approach, could I couple this with closing my eyes?
I'll definitely give the variac a miss then, I might wedge the temperature probe of my meter in the door seal once it's been on for ten minutes and see what I get, fingers crossed if all is well I hope it will just be a case of cleaning her up and sorting out the electrics, then on to the door seal and exterior. Someone did mention a thermal cutout too which I think is a sensible idea - i'll look into this. I'll update this thread with my results, however if you don't hear from me anymore then it didn't go well…just google appliance fires in the York area haha Many thanks, Darren.
25th Jan 2016, 6:32 pm | #49 |
If you're sure the mains flex and internal wiring is ok, there's a good earth right through to the plug, then there's not alot to go wrong.
I have a compressor here with burnt out motor and it just goes mmmmm click when you plug it in, no explosions or noxious gas clouds I wonder if that's the original compressor
Kevin |
25th Jan 2016, 7:00 pm | #50 |
The compressors (sealed ones) are great for handyman stuff. Although they are quite low volume, they will happily pump up to 300 psi.
The motor/compressor runs in a bath of lubricant, usually a poly-glycol PAG oil, so if you find a working one, squirrel it away for a later project. 50% of the time it isn't the motor that dies, it's the PTC resistor/starter/relay farkle that's on the side of the compressor. SWMBO like to see new fridges etc, that's why so many get turfed out. Andrew |
25th Jan 2016, 9:45 pm | #51 |
Hello,
I think that the compressor is a replacement probably from the 1950s. The trademark Sternetic was registered in 1950. This Australian advert from 1951 might be of interest. Yours, Richard Last edited by Mr Moose; 25th Jan 2016 at 9:57 pm. |
25th Jan 2016, 10:53 pm | #52 |
As far as I understand it, chlorofluorocarbons aren't particularly harmful. They were once widely used in spray cans, and even asthma inhalers until just a few years ago. Their popularity was partly because of their low toxicity. However, releasing an excessive amount of any gas in a confined space can displace oxygen and cause breathing problems, which is what the health warnings seem to refer to. CFCs however are not different to carbon dioxide for example, or butane in this respect. As for fridges, although I've heard of many people breaking the coils in their fridge while de-icing, I've never heard of anyone being harmed by it. The only reports of serious health effects I could find involved clearly very large amounts of CFCs being used in industrial situations. So, I don't worry about the CFCs leaking out of my fridge. Well, not for my health at least. It would still break the fridge!
So, that wouldn't stop me using it. I actually have a fridge containing CFCs from about 1980, and I'm sure many others are still being used. However, I would check the electrical condition of an 80 year old fridge very closely before using it. Last edited by Okto1984; 25th Jan 2016 at 10:58 pm. |
25th Jan 2016, 11:19 pm | #53 |
Sternetic (Louis Sterne & Co) were apparently 'absorbed' (no pun) by Prestcold in 1971. They also made 'Sternette' retail freezers for ice cream etc (graces guide)
Kevin |
26th Jan 2016, 12:34 am | #54 |
So it was Prestcold! Thought they had been taken over by one of the big names but could never remember for the life of me who!
Best bet at this point is check the wiring and plug it in. It will either work or not. Worst it will do is trip the RCD or breaker. I find refrigeration kit to be fascinating (you may have guessed), and am watching this tread with great interest. No real domestic experience, but have helped keep quite a few farm refrigeration units running over the years so I know my way around pretty well, though obviously would call in a qualified engineer if refrigerant handling was needed. |
26th Jan 2016, 9:19 am | #55 | |
Interesting to see the ad, it certainly does tie up your theory and the evidence. Many thanks, Darren.
26th Jan 2016, 9:27 am | #56 | |
You don't see these things too often so it certainly is interesting, I may even create a small video of the first run so people can hear it too. Many thanks, Darren.
26th Jan 2016, 12:49 pm | #57 |
Prestcold rings a bell, that was our first fridge, it had quite a heavy door and clunky lock. We traded it in for a fiver with a duff unit and I got a replacement sealed unit from a firm called C W Wheelhouse, in Hounslow I think they were, I know I went and picked it up. Still worked out at a lot less than a new fridge.
Peter |
26th Jan 2016, 9:46 pm | #58 | |
I wonder if in it's original incarnation, if it had a fan directing air to cool the motor, compressor and condenser? That would raise it's efficiency by a measurable amount. I would seal up the electrical connections and take it outside and treat it to a pressure washer. Andrew Last edited by Andrew B; 26th Jan 2016 at 9:55 pm. |
27th Jan 2016, 10:38 pm | #59 |
That fridge would have had a separate motor and compressor when it was new and would have been very expensive thats probably why its owners decided to have it repaired instead of putting it out in the street and hoping it would disappear like everyone seems to do today .Back in the 70s i worked on lots of these fridges and Frigidaire were considered one of the best very well built and beautiful to look at especially some of the 50s models some had interchangeable Formica panels that slotted into the door [you could change the colour when you decorated your kitchen there were also matching washer dryer dishwasher ECT ] and a built in spirit level so the thing could be perfectly level the main reason for that was not simply for getting it to stand up straight but to protect the motor [the electric motor inside an all in one Frigidaire compressor hangs on springs and if operated while not level would rub against the outer case .there was one of these motors cut in half in our showroom for customers to examine]
9th Feb 2016, 2:54 pm | #60 |
Hi Everyone,
Just a quick update this and an apology for the very late reply! I haven't plugged this in yet as i'm having trouble getting access the garage where it is stored (the owner has gone away) As soon as I do you'll be the first to know, and yes I will start recording before I plug it in in case there is a bang / explosion / fire / evacuation My 'Radio Television and Electrical Repairs' book arrived, can't believe I didn't know about this one, very handy to have, thank you to those who suggested I buy this. Many thanks, Darren.
