Old 7th Jun 2019, 11:39 am   #21
borispoodle
Default Re: Philips EL3576 (new) restoration
I did try the metal food can trick to no avail, mu metal is just so expensive so I will not bother unless I find a piece as scrap, thanks cheerfulcharlie. The cable run from the head to the preamp is really long, about 15 inches by the way.
borispoodle is offline
Old 7th Jul 2019, 5:04 pm   #22
borispoodle
Problem solved.
Under the pre-amp pcb lies a thin aluminium screening sheet. That was not adequate.
Mu metal is very expensive.
I found an old crushed organ pipe with walls a good 1mm thick. This was 80% lead. Cut and hammered a 5 x 10" sheet, fixed this as the pcb screen and earthed it to the pre-amp earth. Works great.
