2nd Mar 2012, 4:42 am | #1 |
Do bakelite cabinets really contain asbestos?
This is a daft question, but, do Bush sets use asbestos in the bakelite, as well as wood dust?
Is it safe to sand bakelite, or is the dust toxic? It's a little late to ask this now that I've started sanding, however, I never realised (till after the event) that it was toxic! Is there a need to worry about breathing in some of the dust? |
2nd Mar 2012, 6:27 am | #2 |
Re: Does bakelite really contain asbestos?
Certainly not a daft question. While the composition of any particular cabinet can only be determined by analysis or knowledge of the particular manufacturing process there is certainly evidence that some bakelite has contained asbestos:
http://www.asbestossurveyingltd.co.u...t_cisterns.htm http://www.antiquewireless.org/otb/vt0108.htm http://www.youtube.com/watch?v=Aj_4MDCjHEM Actually any very fine dust can be hazardous but asbestos particles are especially nasty. If you're going to sand it, do it wet which stops any significant release of particles. In normal use there is obviously no significant hazard. The asbestos fraction is small, bakelite is not a dusty material and it breaks cleanly, releasing little or no dust. |
2nd Mar 2012, 8:33 am | #3 |
I think so long as you sand it outside, and wear a dustmask of some sort, you should be ok. I stuck T-cut on the last one I did to keep the dust down! Regards, Lloyd |
2nd Mar 2012, 10:43 am | #4 |
There are different types of Asbestos, if it does contain this stuff what type was used. There are three types, white Crysotile used in roof sheets and some floor tiles, the fibres of this still pose a threat but are not as bad as the brown type Amosite asbestos, blue and brown are the worse. Some toilet cisterns contained asbestos but it was bonded in a resin, could bakelite be the same, if so what type does it contain? Brown Amosite was found in pipe lagging and this sheds fibres easy as it's very fine material.
http://www.packagingtoday.com/introbakelite.htm |
2nd Mar 2012, 11:23 am | #5 |
Re: Do bakelite cabinets really contain asbestos?
Whenever I'm sanding, sawing or filing plastic, wood, bakelite etc. I always wear a dust mask. You can't be too careful with these things!
Rich.
2nd Mar 2012, 11:34 am | #6 |
When rubbing down bakelite, I always do it with wet & dry paper and cold water. That way there is little chance of any dust getting airborne. I don't think asbestos was widely used in the filler material but better safe than sorry.
Mark |
2nd Mar 2012, 2:43 pm | #7 |
I'd be cautious about breathing in any type of dust. I want my lungs to last all my life!
2nd Mar 2012, 3:28 pm | #8 |
We've just had council panic on ours and change it in a hurry. Looked like thick heavy plastic, almost like bakelite, black in colour.
2nd Mar 2012, 5:31 pm | #9 |
Yes, our cisterns at work are of this type. They are the Dauntless Elite model and supply the urinals, they are regularly tested and labelled by Casella Ltd as are the floor tiles.
Neil
21st Mar 2012, 10:28 pm | #10 |
Homes used to have loads of it, ironing boards, kettle and teapot stands, house full of kids playing with bits of the broken stuff that flew about etc. Maybe it was used as a filler in bakelite and elsewhere just to get rid of some of it once it became public knowledge just how deadly it is?
22nd Mar 2012, 7:21 am | #11 |
I think your only real concern with bakelite and asbestos is in the event someone rubbing down, grinding, or in some manner getting into the under surface and exposing fibres. You'd want to avoid this anyway in restoring.
This is how I polish and restore bakelite radios, knobs, plugs etc. I use Brasso, or some kind of copper/brass polish. First ever so lightly dampen the bakelite with a damp rag. Then rub the brass polish with a cheap sponge, the kind where on one side there a soft abrasive side. After this, I go back over with a damp rag removing the polish. When it is all removed, I then use an antique furniture polish oil. LIGHTLY. Then wipe off the furniture oil. Let dry. repeat lightly applying furniture oil and wiping off till a high shine is accomplished. It has always worked beautifully for me. Do not over do the furniture oil and wipe off all excess. You don't want an "oily" finish which will attract and catch all dust and finger prints. |
19th Apr 2012, 6:46 pm | #12 |
I found something that works really well for bakalite .
After cleaning a cabinet recently that was pretty dull .I rubbed it with burnishing cream which is a bit like brasso , it came up average as they usually do , but i then applied sparingly some car dash shine (Tesco brand) The cabinet came up beautifully and has retained the shine for the couple of months since i did it . It looks almost new! |
19th Apr 2012, 7:35 pm | #13 |
Car dash shine..maybe silicone oil? We used that on a brush for rejuvenating bakelite AVO cases. Car dealers have another name for it..
Kevin |
20th Apr 2012, 6:22 pm | #14 |
I wondered if it contains silicone . I wouldn't advise getting silicone on wooden cabinets , but i cant see a problem with Bakelite. It works really well ,is not sticky and the shine looks natural. Its better than using wax which is what I used to use to finish them off with .
I wondered if it contains silicone. I wouldn't advise getting silicone on wooden cabinets, but I can't see a problem with Bakelite. It works really well, is not sticky and the shine looks natural. It's better than using wax which is what I used to use to finish them off with. |
24th Apr 2012, 8:06 pm | #15 |
The finish on Bakelite products was satin not gloss so don't overdo the Brasso and elbow grease. You might end up with a toffee apple..J
