31st Jan 2019, 4:36 pm | #1 |
PCB preparation.
Hello again, When a manufacturer makes a printed circuit board, they first etch the copper coating then they remove the copper as needed (or not needed) then apply the components, then thro a solder wave or similar and then they spray it with a green material to protect the copper and make it look nicer. What I would like to know is what is the green material called. I thought it was a conformal coating but I can't find it in green. I would like to purchase some because I thought it would improve the looks of some of the boards I work on.
31st Jan 2019, 4:53 pm | #2 |
Re: PCB preparation.
The green coating is solder resist and it's applied to the board after etching and plating but before any components are fitted or soldered.
Conformal coating is normally clear and is applied to the assembled board to protect against dirt and damp, if required. |
31st Jan 2019, 5:06 pm | #3 |
Hi Barry, Thanks for your reply. Do you know if this is readily available from the likes of RS or CPC.
31st Jan 2019, 5:15 pm | #4 |
Solder resist is some sort of heat resistant epoxy - I doubt that is available in small quantities but I have never looked for it.
It`s virtually impossible to remove, I do know that. RS do a number of Conformal types including this green one :- https://uk.rs-online.com/web/p/confo...tings/0495240/ Pricey for a pen though. |
1st Feb 2019, 11:56 am | #5 |
It sounds like you need this stuff.
https://cpc.farnell.com/mega/600-051...0ml/dp/PC01663
Howard G7AJN/M3OCL "How hard can it be?" - Jeremy Clarkson |
1st Feb 2019, 12:24 pm | #6 | |
I bought solder resist years ago and never ended up using it (Taiyo ink product) and it is a two pack epoxy (never used it as I now get my pcb's made in China - much cheaper). Don't know the price these days but I think it cost me around $160 for 1 litre. It is also not self curing, it needs to be baked. |
2nd Feb 2019, 1:05 pm | #7 |
Here's a nice video of the production process: https://www.youtube.com/watch?v=ljOoGyCso8s
I also get my boards made in China. Much easier! |
