30th Jan 2019, 8:56 pm | #1 |
Mystery valve?
In a box a valves I was given is a mystery octal type.
Internally it looks like two triodes with seperate cathodes but each cathode has two anodes. Hard to see in the attachments, but the anodes look quite large and are finned. It has a CV number the last digit of which is 4. Any ideas what it might be? Regards Tim
Building and tinkering for over 50 years, from 807's to digital amateur TV. |
30th Jan 2019, 9:02 pm | #2 |
Re: Mystery valve?
30th Jan 2019, 9:12 pm | #3 |
Re: Mystery valve?
I'm impressed ! Yes that's the one 6080, looks like quite a useful PSU type valve.
Regards Tim
30th Jan 2019, 9:23 pm | #4 |
Re: Mystery valve?
It's a good low-impedance valve for use - as you say - as the series-pass element in regulated PSUs.
I believe they were also used in some of the early valve computers to switch the supply to solenoids in things like line-printers and paper-tape/card-punches, where you needed to be able to fire a few hundred mA through the coil to get a fast pull-in. |
30th Jan 2019, 10:33 pm | #5 |
Re: Mystery valve?
Used in some Tektronix scopes for power regulation.
31st Jan 2019, 6:42 am | #6 |
Re: Mystery valve?
I played with the 6080 a lot in the 90s hence my immediate recognition trying to make transformerless audio power amplifiers with moderate success, the efficiency was dreadful.
I was overseas at the time without the family so had time on my hands to play. It's a lovely valve and takes a lot of abuse I still have a few kicking around somewhere Cheers Mike T
31st Jan 2019, 7:36 am | #7 |
Re: Mystery valve?
Yep, a 6080, my Tektronix 585A that isn't working at present uses two of them.
Andy.
31st Jan 2019, 11:01 am | #8 |
Re: Mystery valve?
Ye olde 6080.
Very common in regulated power supplies in the 60's. Good for 250 V and 250 mA, and cruisin'. Reliable and forgiving. |
31st Jan 2019, 1:16 pm | #9 |
Re: Mystery valve?
There appears to be a factory code on the opposite side from the CV mark.
31st Jan 2019, 1:20 pm | #10 |
Re: Mystery valve?
factory code AJ1 R5B4 or R584
Regards Tim
31st Jan 2019, 3:11 pm | #11 |
Re: Mystery valve?
AJ was indeed a code used by Philips/Mullard for the ECC230 and 6080.
R5B4 point to manufacture in Mitcham, the fourth week of february, year 5 (probably 1965). |
