30th Jan 2019, 10:26 am | #1 |
Japanese Transistors and identification?
Can anyone tell me please where i can find info on the equavalents for Japanese trannies , FET,s MOSFET,S namely 2SK19, 2SA733, 2SC945 and everything else Japanese into more familiar designations like BC BF BLY or MPF.
The Japanese stuff is a bit of a mystery. I have quite a few components for identification too so how do i go about finding out what these unmarked packages are , they could be FET,s or Trannies , mostly from the 70s and 80s. Thanks |
30th Jan 2019, 11:09 am | #2 |
Re: Japanese Transistors and identification?
Just google the names. 2SK is the Japanese prefix for an FET.
30th Jan 2019, 11:17 am | #3 |
The go-to for this sort of thing used to be 'Towers International Transistor Selector'. I've just found a browseable copy online here.
https://archive.org/details/TowersIn...sistorSelector Be aware that as this is quite an old publication, some of the transistors suggested as substitutes may be as hard to find as the Japanese ones you want to replace. |
30th Jan 2019, 11:40 am | #4 |
The 2SA733/2SC955 are a complementary PNP/NPN general purpose pair and can be replaced with lots of general purpose types from different naming conventions, e.g. BC558/BC548 or 2N3906/2N3904. Check the leadout arrangements and modify as necessary.
Why do you want to replace these transistors though? They rarely fail. |
30th Jan 2019, 12:41 pm | #5 |
Thanks for the help. Oh yes Towers I remember that book. I'm looking to sort out what I have and identify them and use them in projects or if I don't have them obtain the more recognisable equivalents. I'm just not au fait with Japanese coding. If it's BC, BF or 2N it means something to me.
30th Jan 2019, 12:51 pm | #6 |
I have quite an old edition of Towers which I find quite useful, also several by now old Mullard Data Books (remember those?), and two comprehensive books published by 'Dov' (the 'o' should have a umalaut-two dots above it, b.t.w.), which I bought from Willow Vale back in June 2001. One covers Transistors from A to Z, the other , those prefixed 0 -u (mu). These are all very useful, though now quite old. Data sheets for probably thousands of devices are these days available on the internet of course, but whether any more up-to-date books are available I know not.
30th Jan 2019, 1:21 pm | #7 |
As a very general rule:
2SA = PNP small signal 2SB = PNP power 2SC = NPN small signal 2SD = NPN power 2SK = FET It's not completely consistent though, and the prefix doesn't indicate Ge or Si. You just have to google the datasheet. |
30th Jan 2019, 1:54 pm | #8 |
The other thing to be aware of is that some manufacturers dropped the 2 and sometimes the S as well, when marking their devices. So, a transistor with the legend C945 will be a 2SC945.
Alan |
30th Jan 2019, 3:18 pm | #9 |
Yes and I still have the small Mullard books from 1974 and 75 purple and green! Great little books.
I just don't get along with that japanese legend ident. Thanks for the info again. So in place of the 2SK19 I could go for a 2N3819? |
30th Jan 2019, 3:53 pm | #10 |
They are similar devices, but substituting FETs is always tricky because they tend to have very specific bias requirements. Bipolar transistors are much easier to sub, particularly general purpose types.
30th Jan 2019, 6:41 pm | #11 |
Is there any way of telling from the prefix or number whether a particular transistor is intended for RF or AF applications ?
30th Jan 2019, 7:17 pm | #12 | |
There are quite a few 2SCs which are NPN medium to high power (typically TO126 or TO220) devices rather than T092 small-signal. |
30th Jan 2019, 7:26 pm | #13 |
And lots of 2SBs are actually pretty weedy, especially from the 60s Ge era.
The prefix doesn't indicate anything about the hfe, as with the American 2N convention. You just have to look them up. |
30th Jan 2019, 7:41 pm | #14 |
If you're drawing that conclusion from the fact they both end in '19' I would say no, there was no such intentional co-relation between Japanese, American and European numbering series as far as I know. Each went their own way, mostly.
The '2S' in 2SK19 makes it a FET, as Paul said - you won't find it in the online Towers I linked to earlier because there was a whole separate volume - 'Towers International FET Selector' dedicated just to FETs. I wasn't able to find an online copy in the short time I spent looking. |
30th Jan 2019, 8:01 pm | #15 |
According to my copy of Towers' it's the K that is used to designate an n-channel FET. J (ie, 2SJ) in the same position is for p-channel FETs under the JIS system.
Alan |
30th Jan 2019, 8:01 pm | #16 | |
Another thing to keep in mind, is that on a Japanese transistor, the second line of text is usually the batch code, but it can also start with the suffix. For example a transistor marked C1815 GR1A is a 2SC1815-GR (with batch code 1A). I think GR is a hFE designator in this case. Last edited by Maarten; 30th Jan 2019 at 8:07 pm. |
30th Jan 2019, 8:05 pm | #17 |
All very true. I was talking in terms JIS devices made in Japan.
Alan |
30th Jan 2019, 8:06 pm | #18 |
I think the Japanese system started out distinguishing between RF and AF, not between small signal and power but it seems that it got mixed up a bit, later.
30th Jan 2019, 8:14 pm | #19 |
Towers' again:
2SA - pnp, high frequency 2SB - pnp, low frequency 2SC - npn, high frequency 2SD - npn, low frequency 2SH - unijunction 2SJ - fet, p-channel 2SK - fet, n-channel Alan |
31st Jan 2019, 12:30 am | #20 |
The "S" number actually designates the number of PN Junctions in a given device, hence 1S XXX for Diodes ie. one PN junction, 2S for Transistors ie. two PN junctions, and 3S for the likes of Dual gate Mosfets.
The US system is similar in this regard, ie. 1N XXX for Diodes, 2NXXX for Transistors and so on.
I don't suffer from Insanity. I enjoy every minute of it. |
