Old 15th Jan 2019, 5:03 pm   #1
ssaunders
Default Spring Doohickeys
Folks,
Can anyone tell me what these spring clip doohickey things are called and where I might acquire a supply. In life they cling on to a spigot holding a bezel on the front of a Cossor Melody Maker 500.
Simon
ssaunders is offline
Old 15th Jan 2019, 5:20 pm   #2
mickm3for
Default Re: Spring Doohickeys
Hi similar to starlock washers RS components not the same but for same use also found ebay https://www.ebay.co.uk/itm/Starlock-...-/253723925397 Mick
mickm3for is offline
Old 15th Jan 2019, 7:07 pm   #3
Electronpusher0
Also known as speed fasteners.
Peter
Electronpusher0 is offline
Old 15th Jan 2019, 7:12 pm   #4
Station X
Station X's Avatar
Very similar to Spire Nuts.
Graham. Forum Moderator
Station X is offline
Old 15th Jan 2019, 8:15 pm   #5
Scimitar
Scimitar's Avatar
You will find them listed as Star Washers.
Scimitar is offline
Old 15th Jan 2019, 8:31 pm   #6
Station X
Station X's Avatar
Star washer is another name for a shake proof washer, also known as a serrated washer for use with a nut on a screw or bolt.
What we have here are Starlock washers.
Old 15th Jan 2019, 10:30 pm   #7
Scimitar
Scimitar's Avatar
Agreed.
Scimitar is offline
Old 16th Jan 2019, 1:41 am   #8
Radio Wrangler
Radio Wrangler's Avatar
They get called many things, though not in polite company.
Radio Wrangler is online now
Old 18th Jan 2019, 2:54 pm   #9
Andrew2
Andrew2's Avatar
I call them all the names under the sun as they can be b@"£$%^&*s to remove! There is also a rectangular version and they are used to hold all manner of things in place, including speakers and speaker grilles.
Andy G1HBE.
Andrew2 is offline
Old 13th Mar 2019, 7:11 pm   #10
Uncle Bulgaria
Uncle Bulgaria's Avatar
I had to get some of these for my car. I found the best thing to look for was 'shaft retainer' or 'push fit retainer'. Here is a reasonable selection from Bresco:
https://bresco.com/acatalog/Badge_Fixes-p1.html
Uncle Bulgaria is offline
Old 13th Mar 2019, 8:34 pm   #11
poppydog
I have fitted hundreds of starlock washers on braking systems over the years and have never known the item in the OPs pics called a starlock, doesn't much look like a star.
poppydog
poppydog is offline
Old 13th Mar 2019, 10:17 pm   #12
ms660
ms660's Avatar
Tinnerman do them in the photo in post 1.....(page 21):
http://www.cfi1.com/documents/client/Tinnerman.pdf
Lawrence.
ms660 is offline
Old 13th Mar 2019, 11:44 pm   #13
Uncle Bulgaria
poppydog
It appears a more modern version of the OP's sought-after piece, as others including Station-X have mentioned, is a round push-fitting with the registered mark 'Starlock'. They're for retaining shafts without threading and locknuts. The 'Starlock' type are made by this outfit: https://www.bakfin.com/
While the OP's object isn't a 'Starlock', but a generic form of the same idea, it looks like Lawrence's catalogue has the exact type as ssaunders is looking for on the page he mentioned. A good resource, Lawrence!
