21st Jan 2017, 9:09 pm | #1 |
Another ID Question - Antenna
Can anyone ID the antenna in the attached photo please? It has W1961A stamped on one side, and 1155 N stamped on the other. The elements to the centre of the block are 12.5cm each, which puts it around 570MHz.
I presume it's off an aircraft, but what was it used for? Thanks. |
22nd Jan 2017, 2:29 pm | #2 |
Re: Another ID Question - Antenna
I wondered but could be way off,that it is from a wave meter.
22nd Jan 2017, 8:39 pm | #3 |
The mention of "1155" is intriguing.
I know that during testing of various Airborne Interception (AI) and Air-to-Surface-Vessel (ASV) RADARs there were problems with these causing severe interference to the established HF ground-to-air voice-radio comms to the point where a RADAR-test aircraft could not be recalled when an enemy plane appeared in the area because the RADAR was disabling the HF link. [paraphrased from "The Secret War"]. And that a range of 'suppressor' strategies were subsequently used to try and combat this. Wild Conjecture: Your antenna was designed to be placed so as to get a good belt of UHF RADAR signal and feed it back to some sort of blanking-device fitted in the HF antenna-feed to a R1155 receiver? |
23rd Jan 2017, 7:50 am | #4 |
Gut feeling is that the coax on that antenna is far too recent to be from R1155 days. It does though look to be test equipment related.
Dave |
23rd Jan 2017, 9:46 pm | #5 |
To be honest, I hadn't considered it being part of a wavemeter or other test equipment HB. Good thinking!
The coax is similar to URM57 and the block where the elements are egressing has four through-holes in the corners, which made me think it would have been a secure fitting onto something. I'm just guessing at RAF really, could be army, navy, or something completely different, of course! |
23rd Jan 2017, 10:48 pm | #6 |
What set me off thinking re a wave meter was those nice Marconi types that covered all bands.Though in separate boxes I add.
Somewhere I have one ,absorption type that is.Nicely made wooden boxes 6 inches square or close.
