Old 11th May 2016, 10:59 pm   #1
stevekendal
stevekendal's Avatar
Default DAC90 crack repair
Just bought a nice working black DAC90, the smooth knob version. It was cheap because it has a neat crack on the top of the case. The crack is central and runs from front to back. Best way of repairing and reinforcing. Araldite or fibre matting on the inside?
Knobs and tubes rule ok
stevekendal is offline
Old 12th May 2016, 11:36 am   #2
newlite4
newlite4's Avatar
Default Re: DAC90 crack repair
If it is a clean crack, I would start off by just dribbling superglue into the crack using capillary action. If it is felt necessary to reinforce, then either use fibre glass mat or I tend to use fibre glass veroboard fixed on with araldite.
Neil
preserving the recent past, for the distant future.
newlite4 is offline
Old 12th May 2016, 11:51 am   #3
stevekendal
Thanks, Ill see how the superglue holds
Old 13th May 2016, 9:23 pm   #4
stevekendal
Actually, its split right through, but clean.
Old 14th May 2016, 9:42 am   #5
Lloyd 1985
Lloyd 1985's Avatar
Superglue will hold it very well, I've been using it on Bakelite for years with no trouble. For just a crack superglue on its own will be fine without any strengthening. Make sure to use good quality superglue, not those little tubes that are 10 for a quid are probably not very good, I always use Loctite and have never ha any problems.
Regards,
Lloyd
Lloyd 1985 is offline
Old 14th May 2016, 9:53 am   #6
mark pirate
mark pirate's Avatar
I would reinforce it with fibreglass repair paste, I used it to good effect on my Bush TV32 cabinet.
If the crack is above the dropper though, I don't think it would be a good idea due to the excessive heat!
Mark
mark pirate is offline
Old 14th May 2016, 10:40 am   #7
stevekendal
Just the paste, without tissue?
Old 14th May 2016, 1:34 pm   #8
telstar
Hi Steve. I have used the aluminium that is used on car body repairs, cut in to strips that will suit the size of the repair and araldited in place on the inside of the cabinet to give it a bit of strength.
Mike
telstar is offline
Old 14th May 2016, 7:02 pm   #9
mark pirate
I used just the paste, it is impregnated with fibreglass strands.
If you look through the pictures in my thread you can see how I repaired my cabinet. https://www.vintage-radio.net/forum/...d.php?t=124007
Mark
Old 15th May 2016, 12:36 pm   #10
stevekendal
Done it with Loctite gel. Seems strong enough, just need to make it as invisible as possible now.
Old 16th May 2016, 7:46 am   #11
Lloyd 1985
Lloyd 1985's Avatar
If you let it overspill onto the visible surface then all you need is to sand it flat with very fine wet and dry sandpaper, P600 would be as coarse as I'd go, once flat polish it with either Brasso, T-cut, or greygate paste polishing No.5. It should polish up nicely!
Usual precautions with sanding Bakelite apply, do it outside, and wear a mask, some say that some bakelites contain asbestos. Also leave the superglue for a few days before sanding to make sure it's fully hardened.
Regards,
Lloyd.
