9th May 2016, 9:44 am | #1 |
Plastic plating?
Has anyone yet found a cheap outfit or technique for re-plating chromed/bright metallised plastic trim?
Having been dissatisfied with the use of paint on Bush TR series lettering, my current technique is to superglue the letters to new/un-crumpled 'Baco-foil', trim it off/around the edges etc. with a fine blade, paint the letter edges with very silvery paint, then clear lacquer the lot, all very time consuming! With metal badges e.g 'GMarconi' I usually clean everything off them, polish them up, re-spray them, then carefully cut the raised parts back to a polished finish with very fine wet and dry, and then [again] re-lacquer the lot. (Looks good on 'The Good Companion' etc.) (Incidentally, I've found that Cascamite wood adhesive produces a very good near invisible and opaque [but light translucent] repair on cellulose tuning scales, e.g. on the Philco 444's, which have often been burnt through by the dial light.)
Red to red, black to black. Throw the switch and stand well back! |
9th May 2016, 11:06 pm | #2 |
Re: Plastic plating?
Do any craft shops sell metallic finish Fablon?
Kev Just seen this but there are loads £2.49 for a pack of A4 if I have read it right! http://www.ebay.co.uk/itm/5-METRE-RO...TGvDzpu-JGWmgw Last edited by Oldelectronics; 9th May 2016 at 11:15 pm. Reason: Add text |
10th May 2016, 12:46 am | #3 |
I remember when I was a kid you could buy self-adhesive chrome bicycle handlebar tape - but I haven't seen any of this for many years ...
10th May 2016, 9:00 am | #4 |
I remember that!! possibly now gone up market and migrated to craft/art shops?
Kev |
10th May 2016, 9:22 am | #5 |
Oh, there's still plenty of chrome tape around - Ebay, for instance.
You might also try Speed Tape, a shiny aluminium tape used for temporary patches on aircraft. It's a bit more substantial and has terrific "stick". Cheers, Frank |
10th May 2016, 9:53 am | #6 |
I have here a roll of aluminium-faced insulation-sealing tape - it's "Idenden" brand, made by Bostik:
http://www.bostik.co.uk/construction...-Foil-Tape/306 which sticks extremely well, and can be gently burnished to look rather good. I've used a strip of it to 're-chrome' a somewhat age-worn chrome trim on the dashboard of an E-type Jaguar. |
10th May 2016, 10:23 am | #7 |
Not sure if this will work but worth looking into...
If you have a used bath of etching fluid (ferric chloride), shake it up to distribute the dissolved copper deposits and place the plastic into it. I 'believe' that the plastic will take a coating. IIRC this is how they 'plate' plastic anyway. From there you have to follow the normal electro-plating methods used. Rather hit and miss (I suggest) but perhaps the only way |
10th May 2016, 11:04 am | #8 |
Ho! Do they do 'engine turned' finish as well?
10th May 2016, 11:15 am | #9 |
Hmmmmm ......
Thanks all. These letter are often broken or missing - my current technique is to 're-cast' them by dipping an original into a little blob of molten candle wax and then placing the broken letter into the hardened female 'mould' and running a bit of Aradlite in to it .... but any moulding plastic would do I suppose. Some motor shops supply new plastic lettering - but these will probably never be of the correct size and font/script. E.G. Gerry Wells [RIP] used to recall that he was responsible for the 'raked' 'U' and 'H' on the Bush script ...... !!
10th May 2016, 2:36 pm | #10 | |
10th May 2016, 3:11 pm | #11 |
Good lad .... just testing !!
10th May 2016, 5:38 pm | #12 |
"Lad" I am so chuffed!
Back on topic, electroless nickel is what they use to prime non conducting surfaces for further plating, I have heard it is a tricky process as the container with the solution in can plate its self all of a sudden. |
10th May 2016, 7:23 pm | #13 |
Apparently, colloidal graphite can be used as a base on which to plate, so aquadag or similar might be worth experimenting with.
I believe that most plastic badges and the like are finished using vacuum deposition - not easy at home! |
11th May 2016, 10:20 pm | #14 |
Looks like you could use:
http://www.bare-metal.com/bare-metal-foil.html It is available from: Hobbys or Hannants in the UK There was a company on the Bath Rd just outside Heathrow Airport that did professional plastic plating (very good) I don't know if they still exist, if they do it will be expensive. Good luck Trevor |
11th May 2016, 10:25 pm | #15 |
12th May 2016, 9:36 pm | #16 |
Thanks Trevor!
This may be the way to go.
13th May 2016, 10:29 pm | #17 | |
B |
