Old 31st Jan 2019, 4:36 pm   #1
jim221
Default PCB preparation.
Hello again, When a manufacturer makes a printed circuit board, they first etch the copper coating then they remove the copper as needed (or not needed) then apply the components, then thro a solder wave or similar and then they spray it with a green material to protect the copper and make it look nicer. What I would like to know is what is the green material called. I thought it was a conformal coating but I can't find it in green. I would like to purchase some because I thought it would improve the looks of some of the boards I work on.
jim221 is offline
Old 31st Jan 2019, 4:53 pm   #2
barrymagrec
Default Re: PCB preparation.
The green coating is solder resist and it's applied to the board after etching and plating but before any components are fitted or soldered.
Conformal coating is normally clear and is applied to the assembled board to protect against dirt and damp, if required.
barrymagrec is offline
Old 31st Jan 2019, 5:06 pm   #3
jim221
Hi Barry, Thanks for your reply. Do you know if this is readily available from the likes of RS or CPC.
jim221 is offline
Old 31st Jan 2019, 5:15 pm   #4
barrymagrec
Solder resist is some sort of heat resistant epoxy - I doubt that is available in small quantities but I have never looked for it.
It`s virtually impossible to remove, I do know that.
RS do a number of Conformal types including this green one :- https://uk.rs-online.com/web/p/confo...tings/0495240/ Pricey for a pen though.
Old 1st Feb 2019, 11:56 am   #5
Omegaman
Omegaman's Avatar
It sounds like you need this stuff.
https://cpc.farnell.com/mega/600-051...0ml/dp/PC01663
Howard G7AJN/M3OCL
"How hard can it be?" - Jeremy Clarkson
Omegaman is offline
Old 1st Feb 2019, 12:24 pm   #6
Terry_VK5TM
Terry_VK5TM's Avatar
Slight correction, pcbs are plated after the solder resist is applied these days, saves the cost of plating the whole board.
I bought solder resist years ago and never ended up using it (Taiyo ink product) and it is a two pack epoxy (never used it as I now get my pcb's made in China - much cheaper).
Don't know the price these days but I think it cost me around $160 for 1 litre.
It is also not self curing, it needs to be baked.
Terry VK5TM
https://www.vk5tm.com/
Terry_VK5TM is offline
Old 2nd Feb 2019, 1:05 pm   #7
MrBungle
MrBungle's Avatar
Here's a nice video of the production process: https://www.youtube.com/watch?v=ljOoGyCso8s
I also get my boards made in China. Much easier!
MrBungle is offline
