Old 16th Dec 2018, 9:02 pm   #1
Bigears
Default C-MOS LOGIC Probe
Hi Guys, My Signal tracer Kit K7000 is now working, thanks to you Guys.
I came across this C-MOS LOGIC Probe in a car boot sale and was wondering if I could use it in conjunction with my Signal tracer, or do I use the probe separately?
Bigears is offline
Old 16th Dec 2018, 9:09 pm   #2
Default Re: C-MOS LOGIC Probe
A logic probe won't be much use for working on vintage radios.
It's designed for fault finding on logic circuits such as those found in synthesized signal generators etc.
Station X is offline
Old 30th Dec 2018, 7:12 pm   #3
Bigears
Thanks Graham
Bigears is offline
Old 31st Dec 2018, 11:29 am   #4
boxdoctor
I would add to Graham's comments that it is designed for use on circuits working on about 15 volts or less. If you put a valve radio's HT supply across any connections to the probe, it will destroy the probe circuitry immediately.
Its a useful tool if you decide to have a dabble with digital circuits.
Best to hang on to it, and read up on it. There is loads of info on the 'net on these probes, and they can be very useful. You may find yourself needing to use one one day. Tony.
boxdoctor is offline
Old 31st Dec 2018, 12:33 pm   #5
short wave
R-S sold them there are 2 types
1) TTL type (5 volt)
2) CMOS type 12 volt (or so)
i have one of each
short wave is offline
Old 31st Dec 2018, 2:09 pm   #6
Electronpusher0
They also had a switchable version for TTL and CMOS, it also had a pulse detector with a memory function, I sold mine earlier this year.
Peter
Electronpusher0 is offline
