Old 4th Oct 2005, 4:39 pm   #1
Sean Williams
Sean Williams's Avatar
Default ETF Modulator
Hi All,
I have just finished building the PCB for the ETF modulator - I thought I would share some observations with you all.
The board is very well made, but for later production runs some modifications may be a good idea.
1 The coil formers could do with having a bit more room so that a proper mounting job can be done - either by drilling a .25" hole in the board to allow a mechanical solution, or moving the layout so a standard aladdin type can be accomodated.
2 Some of the solder pads are rather small, and as a result of through hole plating passing leads of larger components can be tricky.
3 Some form of output filtering is essential - the onboard components are not effective with harmonics being generated at significant levels right into the UHF range
But otherwise a simple item to build, and once you have the board it should cost less than a fiver to populate.
With careful choice of coil dimensions you can tune it to channels 1-4 just by moving the slugs......
A picture below!
Sean
Name:	ETF Modulator.jpg
Sean Williams is offline
Old 4th Oct 2005, 6:02 pm   #2
high_vacuum_house
high_vacuum_house's Avatar
Smile Re: ETF Modulator
Hello there,
I look forward to building one. I bought one the week before if I remember correctly but it hasn't arrived yet (dam post!).
I have all of the components apart from the 2 coils and it looks a simple project to build. I think it must go into a screened box to prevent problems.
Christopher Capener
Interests in the collection and restoration of Tefifon players and 405 line television
high_vacuum_house is offline
Old 5th Oct 2005, 6:10 pm   #3
Steve_McVoy
Steve_McVoy's Avatar
Default Re: ETF Modulator
We intentionally didn't put much filtering in the output, because the harmonics won't bother the sets it is designed to work with. The values of the two capacitors and the inductor in the output could be fiddled with to increase harmonic suppression. The board should be fitted in an aluminum box to reduce radiation.
The next time we have PC boards made we will create more space for the inductors. We will also increase the pad size on the components that have larger diameter leads.
If anyone else has comments on the kit, please send PM
Steve_McVoy is offline
Old 5th Oct 2005, 6:22 pm   #4
Sean Williams
Hi Steve,
Point taken on the harmonic emmissions, but it is a problem when you have various HAM recievers in the same room, and of course we all ought to do our bit to supress harmonic emmissions.....
I certainly had no gripes regarding the modulator board, just a couple of suggestions - considering the low cost of the parts this is really very good - it may be worth looking at a double sided board with a ground plane on the upper face - this will allow a screen to be attached to keep the audio and video oscillators seperate, and reduce mixing products from the oscillators.
I am very pleased however with the unit thus far, when I have finished the build I will post some more observations.
I wonder has a review been done for anyone of this design - if not I would be happy to do so!
Sean
Old 5th Oct 2005, 7:50 pm   #5
ppppenguin
ppppenguin's Avatar
Sean
Well worth you writing a review. Either for this forum, the BVWS Bulletin or both. I know you are very well equipped for the RF side of things but if you need any extra input on the video side I'm always willing to help.
ppppenguin is offline
