Old 8th Feb 2006, 12:26 am   #1
Station X
Station X's Avatar
Default DAC90A. Heat shielding of dropper resistor?
Should the dropper resistor of a DAC90A have any form of heat shielding? I know that the dropper in the DAC90 is wrapped in asbestos, but this doesn't seem to apply to the DAC90A.
The one I am working on has burnt/melted sleeving on wires close to the dropper and the paxolin board to which the dropper is screwed is blackened. All the components in the set test OK apart from the coupling capacitor feeding the UL41, which is leaky. Could this have resulted in enough excess current through the dropper to do the damage? The UL41 is actually OK according to the valve tester! O/P transformer is OK too.
Graham.
Station X is online now
Old 8th Feb 2006, 12:30 am   #2
Nickthedentist
Nickthedentist's Avatar
Default Re: DAC90A. Heat shielding of dropper resistor?
Hi Graham,
No, there's no heat shield as far asI can remember.
I think your capacitor theory could well be right. Other causes, I suppose, could be incorrect voltage setting, or running the set hard up against a wall, depriving it of ventilation
Nick.
Nickthedentist is offline
Copyright ©2002 - 2019, Paul Stenning.
