Old 3rd Mar 2011, 6:43 pm   #1
EF80TVVALVE
EF80TVVALVE's Avatar
Default 1 valve radio
Hi, does anyone have any diagrams of a 1930s 1 valve radio with simple circuitry. also does anyone have any photographs of the innards of one. I would like one that uses a 4 pin valve,
thanks
EF80TVVALVE is offline
Old 4th Mar 2011, 7:19 am   #2
gulfstream
Default Re: 1 valve radio
Hello.
I have Frank C. Jones Radio Handbook from 1937 in scanned .jpg format, can be converted to .pdf The whole book is 42 jpg's (2 pages in one jpg) about 22 mb.
Find attach a one valve circuit, using a No 19 valve, maybe that is what you are looking for.
ID:	47743   Click image for larger version
ID:	47744   Click image for larger version
ID:	47745   Click image for larger version
gulfstream is offline
Old 4th Mar 2011, 7:52 am   #3
gulfstream
Correction to my last post.
I do not have the whole book, the whole book is over 200 pages, I only have 81 pages and the cover. Found two more books, "What To Build" Vol. II No. I, also with a 1 valve circuit, and a very nice book in .pdf format, "Knock-out Receivers" 65 pages 25 mb, by Arthur H. Lynch, very detailed, cabinet making, chassis lay out, drilling patterns and lots of informative photos and drawings.
I was happy to "re discover" this book again after forgot about it for several years. When you see those construction and the beauty of bygone receivers, it encourage and enliven you to build them.
Let me know if you like to have those books and I can mail it to you.
von Vulpes
Old 24th Jun 2011, 10:12 am   #4
Norm_N_Tam
Norm_N_Tam's Avatar
thanks
This website has a simple circuit, using a 4 pin valve:
http://www.makearadio.com/tube/1-30.php
Just about any triode valve will work in this circuit!
Norm_N_Tam is offline
Old 24th Jun 2011, 1:45 pm   #5
Andrewausfa
Andrewausfa's Avatar
I have a book by FJ Camm which has one in. This then progresses, with additions to the circuit, to a two valve etc etc
Andrew
Invisible airwaves crackle with life. Or they should do.
BVWS Member
Andrewausfa is offline
Old 24th Jun 2011, 5:55 pm   #6
EF80TVVALVE
could you possibly scan it?
thanks
Old 24th Jun 2011, 6:10 pm   #7
neon indicator
No Longer a Member
Plenty old fashioned one valve designs here
http://translate.google.com/translat...636563&act=url
Original German http://www.andreadrian.de/sdr/#mozTocId636563
neon indicator is offline
Old 24th Jun 2011, 6:17 pm   #8
murphyv310
Very interesting and informative site. Thanks for posting Neon!
murphyv310 is offline
Old 24th Jun 2011, 7:12 pm   #9
Dave-N2DS
Here is a one valve radio that I restored to operation that was built in 1922.
http://makearadio.com/restoration/pa...estoration.php
I drew the schematic and put it up on the page.
The radio originally used a 00A valve which is a "soft detector" or gas filled
valve. I didn't have one of those so I used a #30 valve as a replacement.
I had to add a grid leak resistor so that the grid wouldn't block.
I later plugged in a 01A and lit it with a 4 volt battery. That worked very
well too.
There is nothing like having a MW radio that uses 4 controls to select the station!
This would be a good radio to build if you want the olde time feeling.
Best wishes,
Dave
Amateur Radio N2DS
Dave-N2DS is offline
Old 25th Jun 2011, 1:22 am   #10
Spencervs
Spencervs's Avatar
wow I really want to try building a short wave radio... I have a spare ECL83 valve, could I use this to make one? if not what valves could I use??
Spencervs is offline
Old 25th Jun 2011, 1:54 am   #11
Spencervs
Spencervs's Avatar
actually, I have a wrecked Bush SRP31 record player with no turntable and just the amplifier... could I build a reciever in the bit where the turntable was and have it as a radio?? I would rather it be FM... or maybe FM and shortwave... is this possible?
Old 25th Jun 2011, 7:33 am   #12
Norm_N_Tam
Norm_N_Tam's Avatar
You certainly can build a short wave radio, with your ECL83. The ECL83 is a triode-pentode valve, some info about it can be found here:
http://www.radiomuseum.org/tubes/tube_ecl83.html
There's a receiver using a ECL80 at this site:
http://www.vintageradio.me.uk/info/repanco.htm
If you use this circuit with the ECL83 in place of the ECL80, tie the cathodes together. The ECL80 uses a common cathode for both sides:
http://www.radiomuseum.org/tubes/tube_ecl80.html
Norman
KA1GUK
Old 25th Jun 2011, 8:12 am   #13
Andrewausfa
thanks
Actually I just found this project was discussed a few pages back and it has a scan of the whole book linked...which could've saved me 2.50
https://www.vintage-radio.net/forum/...ad.php?t=46474
BVWS Member
Old 25th Jun 2011, 9:29 am   #14
neon indicator
No Longer a Member
You can pretty much make SOME kind of radio with ANY valve.
I was going to say any Triode, Pentode, Hexode, Heptode, tetrode etc.
But of course a big aerial and valve diode instead of "cat's whisker" will do something!
Old 25th Jun 2011, 2:52 pm   #15
Spencervs
Spencervs's Avatar
I was thinking of using my Bush SRP31 record player's amplifier which takes two ECL83 valves, removing the turntable and everything inside (as it's beyond repair) and building two circuits, one for FM and one for SW witrh a switch inside to alternate. Would I still need to put a valve in the circuits? because surely the valves in the amp will suffice? because the valves are for amplification, right? or do they have another function?
Old 25th Jun 2011, 6:12 pm   #16
neon indicator
No Longer a Member
A VHF radio with 2 x ECL 83 might be possible
Assuming a triode part of an ECL83 works at 100MHz!
1 triode mixer/osc
1 Pentode IF amp
two OA47 or 1N4148 as discriminator
1 triode audio preamp
1 pentode headphone amp.
In Radios Valves are used as
Oscillator
Mixer (or combined Mixer /Oscillator)
AM or FM detectors (though by 1960s Germanium diodes, OA81 etc took over)
RF amps /AGC
IF amps / AGC (AM)
IF amp Limiters (FM)
Audio preamp
Audio driver
Sometimes mains rectifiier
Sometimes Magic eye tuning indicator
Maybe even AFC
Old 25th Jun 2011, 7:37 pm   #17
murphyv310
A one valve Acorn 956 running a super regen circuit works amazingly well on VHF FM frequencies. A two valve circuit is very sensitive and often better than complex tuners.
Old 26th Jun 2011, 4:45 am   #18
Norm_N_Tam
Norm_N_Tam's Avatar
You may wish to have a look here:
http://cool386.tripod.com/fremodyne/fremodyne.html
And here:
http://cool386.tripod.com/fremodyne/fremo2.html
And, finally, here:
http://cool386.tripod.com/fremodyne/fremo3.html
There's some good info about simple super regen FM circuits there.
Norman
KA1GUK
Old 29th Jun 2011, 8:58 pm   #19
neon indicator
No Longer a Member
This Russian valve is readily available on eBay
http://makearadio.com/tube/russian-loop-radio.php
you can probably use 1j18b, 1j17b, 1j29b either.
One valve regen radio
Copyright ©2002 - 2019, Paul Stenning.
