Old 29th May 2019, 5:56 pm   #1
jameshunt8082
New Member
Default Need a very low power 500Khz working transmitter to send morse code.
I have purchased a Marconi Atlanta Marine Radio.
I am purchasing a non-working Oceanspan Transmitter.
I want to demonstrate it working.
I need a very low power 500kHz transmitter that I can use alongside the receiver and I need the transmitter to also transmit on another frequency 512kHz to show, how we used to use 500kHz as a calling frequency.
There output power can be in mWatts.
jameshunt8082 is offline
Old 29th May 2019, 9:46 pm   #2
Station X
Station X's Avatar
Default Re: Need a very low power 500Khz working transmitter to send morse code.
Signal generator feeding a dummy load?
Graham. Forum Moderator
Keep the soldering iron hot.
Station X is online now
Old 29th May 2019, 10:27 pm   #3
Julesomega
Julesomega's Avatar
I promise I'm going to stop collecting radios when I've got an Atalanta 2207C
- Julian
It's good here
Julesomega is offline
Old 29th May 2019, 11:33 pm   #4
G0HZU_JMR
There's lots of ways to generate the signals, including a 74HC4060 and crystal(s).
However, as you will be running the transmitter right next to the receiver I would recommend running the signal source at twice the frequency (continuously) but key a flipflop divide by two (74HC74?) as the morse sender ahead of the final stage and LPF. That way, there will be 'nothing' heard in the receiver in the gaps between morse characters, i.e. no constant low level leakage tone if the transmitter is right next to the receiver. Otherwise, you would have to screen the low level stages of the transmitter very well in order to avoid a constant leakage tone appearing in the background in the receiver.
The alternative is to key the oscillator on and off but that will probably sound a bit chirpy and unpleasant.
Regards, Jeremy G0HZU
G0HZU_JMR is online now
Old 29th May 2019, 11:50 pm   #5
paulsherwin
paulsherwin's Avatar
It really all depends on what you want to do, which isn't very clear at the moment.
paulsherwin is online now
Old 30th May 2019, 12:13 am   #6
G0HZU_JMR
Yes, it's not that clear. I assumed it would be the receiver connected to a regular outdoor antenna and the transmitter sat alongside the receiver running into a dummy load. The risk there is that the radiated morse signal from the dummy load might not be that much greater than the leaked radiation from the unkeyed oscillator inside the transmitter.
Old 30th May 2019, 8:04 am   #7
G3VKM_Roger
G3VKM_Roger's Avatar
I would also suggest the use of crystals and a divide by n chip, as you can then use a crystal around , say, 5120kHz which are quite plentiful and divide that down to 512kHz. I did a similar mod to a Marconi Commandant to get LSB on it and needed a crystal around 100kHz.
HTH
Roger
G3VKM_Roger is online now
Old 30th May 2019, 9:21 am   #8
Jon_G4MDC
Jon_G4MDC's Avatar
Jeremy's 4060 divider method provides the answer to on/off keying without spacer wave for free by using the reset line Pin 12.
An 8.0MHz crystal should produce 500kHz at the first output Q4, Pin7. Use an 8.192MHz crystal instead (also commonly available) for 512kHz output.
Jon_G4MDC is online now
Copyright ©2000 - 2020, vBulletin Solutions, Inc.
Copyright ©2002 - 2020, Paul Stenning.
