20th May 2019, 3:21 pm | #1 |
Nordmende loft find. Any value?
Hi everyone. I'm a new member and this is my first post.
Found this in my loft. I quite like the look of it, I'm wondering if it has any real value? I'm sort of tempted to rip its guts out and turn it into a Bluetooth speaker but at the same time that would be an awful shame. Thoughts? TIA Lee. |
20th May 2019, 3:46 pm | #2 |
Re: Nordmende loft find. Any value?
Heresy! Have you tried it to see whether it works?
Paul |
20th May 2019, 3:57 pm | #3 |
Not sure. Just taken the back off, looks like it needs one of those square batteries (which I don't have)
20th May 2019, 4:07 pm | #4 |
It would most likely restore up to work as a perfectly good FM radio.
I bet there are enough contacts on the switches to make it activate one of those little blue tooth boards with the wave change buttons not pressed. The existing amplifier and speaker will be just fine too. |
20th May 2019, 4:21 pm | #5 |
I cannot see the logic in wanting to Bluetooth an old radio, each to their own I suppose..
20th May 2019, 4:48 pm | #6 |
It looks a bit shabby but searching threads will reveal techniques to bring the red and gold finish up to nearly as new. I would start there perhaps-especially if your tech knowledge is limited. That would maximise it's vintage value but gutting it might well take you in the opposite direction. There's plenty of advice available if you are interested in repair restoration?
Dave W |
20th May 2019, 4:51 pm | #7 |
It's an interesting early FM transistor radio, but it will need some restoration if it's going to be used and I get the impression that you're not interested in that side of things. It would be better to pass it on to somebody that would restore it rather than gut it. There are plenty of modern sets with retro styling if that's what you want.
It's not worth a fortune, maybe £10 as it stands. |
20th May 2019, 6:00 pm | #8 |
20th May 2019, 6:17 pm | #9 |
... which will be £10 more than it's worth once it's had it's original guts ripped out !
It's a nice old thing that deserves to be restored.
Chris |
20th May 2019, 6:29 pm | #10 |
Indeed, it will be of no interest to collectors and vintage radio enthusiasts if it is modified irreversibly, even if you make a very good job of it.
20th May 2019, 6:45 pm | #11 |
Wow! So many replies! You've clearly got a good community here.
Hmm.. I tend to agree with the sentiments about destroying it just to modernise it. However, I do like the idea of having something quite old (relatively) that functions in a modern way.. Thanks for the advice in restoring the exterior, perhaps I'll start there. Maybe I won't want to ruin it after it's looking nice again. Once again thanks for everybody's input. Lee |
20th May 2019, 8:16 pm | #12 |
But it WILL perform ion a modern way. Maybe not a lot on the AM bands, but I have never seen a GERMAN NordMende that did not have first class FM reception. I would wager that listening to Radio 3 on that set will make you sit up and take notice.
The 603 series led onto even better sets as the early '60s moved on. Les. |
20th May 2019, 8:36 pm | #13 |
Possibly a PP9? These are, or were until very recently, available at Wilkinsons. If not they are to be had on line
Paul |
20th May 2019, 9:31 pm | #14 |
Our local B&Q still stocks PP9s
Peter |
20th May 2019, 9:53 pm | #15 |
According to that Radiomusum page, it takes 2 x 4.5v. Batteries. Would these have been the flat type once commonly available by any chance?
20th May 2019, 10:13 pm | #16 |
Yes, they were very widely used in portable radios from continental Europe.
20th May 2019, 10:28 pm | #17 |
These are great and quite sought after little sets - particularly in that colour. They perform very well and sound better than many contemporaries - probably because the cabinet is actually timber [rather than plastic] covered in Rexine. The 'on/off + volume switch is a bit of a weakness and will probably require cleaning - but I bet if you put a battery on it, it will work.
P.S. Please ensure that you connect the battery with the correct polarity - those old Ge sets don't respond favourably to reverse polarity!
Red to red, black to black. Throw the switch and stand well back! |
20th May 2019, 10:46 pm | #18 | |
At present I doubt there will be much wrong with it. John. |
21st May 2019, 12:11 am | #19 |
I have got a French LW/MW set and I managed to get two 3 AA cell holders in the space and used tabs to connect them to the original terminals. Again it has a timber cabinet and sounds at least as good as a TR82.
21st May 2019, 2:58 am | #20 | |
I hope yours works, I often take mine out with me in my old Rover to classic car shows. It probably dates from around the same time...1962.
Clive |
