Old 19th Apr 2019, 5:41 pm   #21
winston_1
Default Re: Another pulse to tone possibility
Originally Posted by giraffenigel View Post
It's working! Because of the lack of instructions I had assumed that it was wired the same as the alldav and Dialgizmo as they all look the same - not so! The RJ11 socket is the output and the other end is the input.
I wired a female BT to the 2 terminals inside and an RJ11 to BT plug into the socket and it works perfectly. Remember when wiring the lead that the 2 INSIDE contacts on the RJ11 are the line.
I'm confused now.
I originally wired it with the phone connected to L2 and P1 with the line going to the RJ45 socket as that seemed the obvious way, but it did not work. Seeing your post I tried the phone into the RJ45 socket and the line to L2 and P1. It still does not work.
So which is the correct connection? Though whether it really matters I'm not sure as it does not work either way.
winston_1 is offline
Old 19th Apr 2019, 9:44 pm   #22
Graham G3ZVT
Graham G3ZVT's Avatar
The last sentence of giraffenigel's post is likely to be significant. If the line cord you are using came from a phone it is likely that pins 2&5 on the BT plug are connected to the outer pair of the RJ11, that won't work. 2&5 of the BT plug need to connect to the inner pair of the RJ11.
Graham.
G3ZVT
Graham G3ZVT is offline
Old 20th Apr 2019, 10:51 am   #23
giraffenigel
Rambo1152 is correct, the line from the socket has to go from the inner 2 of the RJ11 plug to 2 & 5 on the BT plug, I had to make one.
giraffenigel is offline
Old 20th Apr 2019, 10:54 am   #24
winston_1
My RJ45 is connected correctly. I get dial tone, the LED on the board lights. But the device does not work. DTMF tones are not generated and dial pulses are not suppressed on the line.
Old 20th Apr 2019, 10:54 am   #25
giraffenigel
Winston 1, if you aren't able to get one PM me your address and I'll send you one.
Old 22nd Apr 2019, 7:45 pm   #26
winston_1
That's a kind offer. Thanks. PM sent.
Old 23rd Apr 2019, 6:29 pm   #27
dagskarlsen
dagskarlsen's Avatar
I have orderered on of these: https://bre.is/ujD4GEKd2
It should be a kind of rotatone copy with polarity guard. If it works I'll by one more.
dsk
dagskarlsen is offline
Old 23rd Apr 2019, 6:56 pm   #28
Graham G3ZVT
My guess is the dial connects to G, O & P,
Ground (com), Off- normal & Pulse, but it looks as if you have to improvise your own terminals using the holes in the PCB.
Graham.
G3ZVT
Old 23rd Apr 2019, 7:27 pm   #29
dagskarlsen
I have used a similar or close to in 2015, but sold the phone, yes the pinout was as you described.
Old 24th Apr 2019, 3:29 pm   #30
winston_1
For closure I'm glad to say PAYPAL have now refunded the full amount.
Old 25th Apr 2019, 2:15 pm   #31
dagskarlsen
dsk
It came today, and I can not see any difference from what I got in 2015.
Pinout: the 2 wires goes to where the pulse contacts were connected before, and G= common O=normally open contact set, and P = the pulsing contact
You dial a digit, and hear the dtmf, holding 1 at the finger-stop until beep is heard and release=redial last number, similar with 2 and 3 dials * and #
It may be more but it came without any documentation at all.
I'll order one more today
dsk
Old 29th Apr 2019, 7:55 am   #32
dagskarlsen
I have done a little more testing, and a capacitor across the 2 pink wires gives a better voice quality, 2uF did it.
I did also try to connect it across the line, since the terminals are mareked L1 and L2, but that almost took all the signals from the phone.
I am working on a manual for later use.
dsk
Old 29th Apr 2019, 5:42 pm   #33
dagskarlsen
Could I please get some help with the English, this is translated from my language Norwegian and are probably far from perfect. Text on the pictures are not easy to manage. Link for downladable doc.
Please feel free to do wht you want with it, but I will not be responsible for any miss use of what I have experienced, and give no warranties
Thank you
dsk
Old 29th Apr 2019, 6:35 pm   #34
Dave Moll
Dave Moll's Avatar
I have downloaded your document and and am happy to proof-read and adjust the text for you. If you PM me with your email address, we can bounce the text between us until we are both happy.
Two questions at this stage: Is "Dialor 1" the name (and thus intentionally spelt that way)? Do you wish to end up with British or American spellings?
Dave Moll is online now
Old 4th May 2019, 9:23 pm   #35
dagskarlsen
Thank you, I have now got fantastic help from Dave Moll for the UK English version, and to Stuart Bauman for the US English version.
Here they are: UK version
US version
Please feel free to use and share this.
dsk
Old 13th May 2019, 3:28 pm   #36
dagskarlsen
Here is the original manual!
I have problems reading this, but the pictures confirms what we have written ourselves, they have not found the idea with the 2uF capacitor, and they have something about cleaning and adjusting dial contacts.
The dial looks equal to the Antwerp telephones.
dsk
Old 13th May 2019, 3:46 pm   #37
Dave Moll
Dave Moll's Avatar
Not being able to read Chinese, I am left with just the pictures. Without intelligible words, I find pictures alone difficult to follow.
I can confirm from experience the importance of clean dial contacts, as a thin layer of (non-conducting) oxidation that is easily overcome by line current can look open-circuit to the much smaller currents within the electronics of an internal tone pulse-to-converter such as a Rotatone. Stand-alone converters such as Dialgizmo do not rely directly upon the dial contacts, presumably operating by detection of the break in loop current.
Old 13th May 2019, 4:05 pm   #38
dagskarlsen
something has happend to the links ower, maybe this will do for the UK English version?
https://bre.is/t4zM6yHtO
dsk
Old 13th May 2019, 5:03 pm   #39
dagskarlsen
Here with comments. https://bre.is/XlwhCO6yW
I hope my English is better than my Chinese
dsk
