Old 10th May 2019, 3:12 pm   #21
telstar
Default Re: Decca PC/ML Console radio of 1939 find
Originally Posted by Atlantic 52 View Post
Thanks Mike, its interesting to learn that two build types were made. From what I can find out it seems that my PC/ML is a rare set. Yesterday I had a go at the field coil. I made up a coil holder cum winding rig on an old piece of chipboard and used a couple of re-inforcement straps to hold the reels. I cut out two hardboard 'caps' to mount the field coil. I'll post a video later but for now enclose some photos. Turning the reels by hand took hours & hours! I finally got to the break and of course they had to be right near the core! Two greenspot points, multiple turns were corroded, one of which had obviously burnt out with current. Cutting a long process short I re-wound the coil bobbin using my battery electric drill with plenty of speed control and care! By 11:30pm I had it wound. I now have to cover and re-solder the connection wires before re-fitting the hum bucking coil. This is not a job for the feint hearted! Does anyone know the gauge of this wire? I don't have a micrometer. Thanks.
Hi. Many thanks for your reply.
The American octal type was brought to me for repair, the pointer drive cord was broken - this was not shown on the manuals. The owner never returned to collect the radio either. The material that was incorporated in the back cover also suffered badly.
Hope you get your speaker sorted out
Mike
telstar is offline
Old 10th May 2019, 8:10 pm   #22
Ed_Dinning
Hi, wire gauge is probably 0,1mm or less
Ed
Ed_Dinning is offline
Old 10th May 2019, 8:52 pm   #23
Atlantic 52
Atlantic 52's Avatar
Hi Jerry,
I too saw that and thought it's not worth me spending that sort of money on a set I might not keep then lose money on. I plan to try it out next week, I just need to find the time!
Regards, George
Atlantic 52 is offline
Old 10th May 2019, 9:24 pm   #24
cathoderay57
Hi George, yes, I know what you mean. Sadly it is going the same way with the cost of HT transformers, valves, especially magic eyes and audio types. Thankfully the folks on this Forum will often help out when they can, at affordable prices, or at BVWS events. Cheers, Jerry
cathoderay57 is offline
Old 21st May 2019, 11:02 am   #25
Atlantic 52
Hello to all looking,
I have finally got the set running after replacing 10 capacitors, the O/P Tx and rewinding the field coil and replacing a rather danerous mains lead. The set works well but I have a low level mains hum from the 10" speaker which is a little annoying. I reversed the hum bucking coil which did make it a lot better but its not quite good enough. Does anyone have any suggestions on how best to improve it? I am minded to add a few uF extra to C19 (8uF) but don't want to overload the R2 rectifier. Its also a real pain adding value due to stripping it all out again, especially that autotuner pack! The set can be seen running at https://www.***********/photos/atlant...7706885637031/
Old 21st May 2019, 11:44 am   #26
HamishBoxer
HamishBoxer's Avatar
Sounds great, I cannot hear the hum though.
HamishBoxer is offline
Old 22nd May 2019, 8:55 am   #27
rontech
A thought occurred to me that if you are listening on line via laptop speakers, I doubt if they would reproduce low level hum
I used to monitor my computer audio from the headphone socket into an old hi fi system with big loudspeakers. Surprising how good some online stuff can sound.
Time flies like an arrow, fruit flies like a banana
rontech is offline
Old 22nd May 2019, 7:02 pm   #28
Atlantic 52
Hello Guys,
The hum would probably be hard to hear due to my recording plus the listening set up your end of course. Its not bad but just a little irritating. You can get used to it but it nags. I'll try a few more uF sometime in the winter or a rainy day. For now I'm enjoying listening to it.
Old 22nd May 2019, 7:40 pm   #29
HamishBoxer
I was listening through the monitor speakers.
