Old 10th Dec 2018, 2:39 pm   #1
Paulus.d
Default Bush SRP31D....
I've just got one of these, I had one when I was younger.
deck service completed I thought I'd test it out!
It had no cartridge so fitted one from a stereo MIDI system...It plays well , very loud good quality sound …… for about five minutes! Then it starts to distort the bass of the music. It makes a crackle sound along with the bass....
Switching off and allowing time to cool, it goes back to being good again for another five minutes...
What do you guys think??
Cartridge output too loud?
Dead speaker?
or amp playing up?
I did try placing a resistor in line with the cartridge output ...it made no difference.....
Any ideas
Paul
Paulus.d is offline
Old 10th Dec 2018, 2:42 pm   #2
ben
ben's Avatar
Default Re: Bush SRP31D....
That sounds like the selenium rectifier is short circuit to me. Stop using it. Search the forum for info on how to go about replacing it with a few components costing pence.
Ben.
ben is offline
Old 10th Dec 2018, 2:57 pm   #3
Nuvistor
Nuvistor's Avatar
Selenium rectifier is one possible cause, output valve(s) drawing grid current is another, this would lower the HT as well.
Frank
Nuvistor is online now
Old 10th Dec 2018, 2:57 pm   #4
Paulus.d
Thank you , yes I thought that might be the case … I've just got the service data sheets and printed them at work !
Paul
Paulus.d is offline
Old 10th Dec 2018, 4:26 pm   #5
John10b
Hi Paul I was interested to note that you used a cartridge (head) from a midi system, and you said all was well with plenty of volume for a short time.
What midi system is it, i ask because I’m curious about the cartridge giving sufficient output to give you plenty of volume. The original cartridge gives out up to 500mVolt, according to the Bush manual.
John10b is online now
Old 10th Dec 2018, 5:50 pm   #6
Paulus.d
The volume isn't lacking … it's very loud..!!!!
Used one of these...
Paul
Paulus.d is offline
Old 10th Dec 2018, 6:22 pm   #7
Looks like the well known "Chinese cheapy" in its slightly better metal shank stylus version. They can give a more than half decent account of themselves in the slightly better class of portable record player.
The Bush SRP31 has a decent push pull multistage amplifier so would be a good match for such a medium output ceramic cartridge.
Herald1360 is offline
Old 10th Dec 2018, 6:41 pm   #8
John10b
Thank you Paul, I know that cartridge well, and yes it does perform well particularly considering it’s low cost.
Old 11th Dec 2018, 1:20 am   #9
Techman
Techman's Avatar
The original selenium rectifiers are a known problem in these, but usually they're bad from first switch on, rather than start OK and then go down after a few minutes, but anything's possible. If you find it's been replaced by a modern diode, check that a 'watty' series resistor has been added, otherwise it'll kill the valves after a while. Some folks think it doesn't matter, but I say it does. The ECL valves aren't the strongest, and unlike a radio that gets turned off when not in use, a record player tends to get forgotten when records are finished and can get left on for hours and sometimes over night.
The grid coupling capacitors are often the reliable Mullard mustard types, so don't generally go leaky, but check the type and measure for leakage just to be safe. The valves can develop grid current of their own if they've been thrashed with an HT supply that's too high due to lack of a series resistor when a new rectifier diode has been fitted.
Techman is offline
Old 27th Dec 2018, 11:45 am   #10
Paulus.d
Default
Here's some pics, looks like the rectifier has already been dealt with.
ID:	175221   Click image for larger version
ID:	175222   Click image for larger version
Paulus.d is offline
Old 27th Dec 2018, 11:58 am   #11
Paulus.d
A quick resistance check on the rectifier, no ohms readings it's gone open circuit!
Paulus.d is offline
Old 27th Dec 2018, 12:10 pm   #12
Have you tested it both ways, preferably using the diode test facility of a DMM?
The leads look to be painted, so take you readings from the terminations.
Station X is online now
Old 27th Dec 2018, 12:16 pm   #13
Paulus.d
The diode in there is reading okay when metered from the terminals, so is it missing the watty resistor?
Paulus.d is offline
Old 27th Dec 2018, 12:22 pm   #14
I think you mean the series dropper resistor which compensates for the lower forward volt drop of a silicon diode when compared with a metal rectifier.
It's the large cylindrical object to the left of the diode. What does it say on it? If it tests OK I se no reason to replace it unless the HT voltage is incorrect. Measure it.
Old 27th Dec 2018, 12:25 pm   #15
Paulus.d
250R it reads and its near bang on.
Paulus.d is offline
Old 27th Dec 2018, 12:36 pm   #16
Check the HT voltage and compare it with that shown on the circuit diagram. While you're at it check that there's no positive voltage on the control grids.
Those black/yellow/red Plessey caps are prime candidates for replacement. They're cathode bypass caps and if electrically leaky they'll change the bias conditions.
Old 27th Dec 2018, 12:41 pm   #17
Paulus.d
I thought they would be ...lol I've just cleaned the valve pins - they were black!
what should I set the DMM to?
Paulus.d is offline
Old 27th Dec 2018, 1:03 pm   #18
Paulus.d
It looks like about 211v it started high then decreased over 5 seconds or so ...
the diagram shows it to be 220v .....
Paulus.d is offline
Old 27th Dec 2018, 1:15 pm   #19
DC Volts. 211V is fine. Check the other voltages they're all DC.
Old 27th Dec 2018, 1:26 pm   #20
Paulus.d
Mainly concentranting on those horrible Hunts caps, C4 and C10, the DC voltages there are lower than the diagram says. Instead of 1.5V it reads 0.97V and instead of 12V it's 5.5V.
Paulus.d is offline
