19th Mar 2017, 10:26 pm | #1 |
Reel to Reel Compatability
Hi - Completely new to this site so apologies in advance for any posting issues.
Does anyone know if the BSR Westminster 4-track is an equivalent to the Dansette Consort 4 - Visually they look the same. Also are there any other makes that match the Dansette ? I have a few reels recorded on the Consort 4 & want them transferred to CD but don't have any machine - It seems that the Consort 4 is a little rarer than I thought even though they were mass produced. Any help / advice appreciated. Thanks |
19th Mar 2017, 11:05 pm | #2 |
Re: Reel to Reel Compatability
They both probably use the BSR TD2 deck, but you can use any 4 track recorder which will run at the right speed (3.75 ips). If you only have a few tapes to digitize then you may be better paying someone else to do it.
Westminster was a brand, sold by Currys. The BSR branding relates to the tape deck, not the whole recorder. Most British domestic recorders of the 60s had BSR decks, either the TD2 (single speed) or the TD10 (three speed). Radiomuseum.org have an entry for the Consort: http://www.radiomuseum.org/r/dansette_consort_4.html |
19th Mar 2017, 11:35 pm | #3 | |
When I die, please don't let my Wife sell my collection for the amount I told her I paid for it! |
20th Mar 2017, 1:30 pm | #4 |
Sometimes there can be an alignment problem if played back on a machine it was not recorded on. It might be easier, better and cheaper for you to have the transfer made by a professional company rather than hunt around for a working tape player with a TD2 deck in it. A Transfer company might even be able to optimise the azimuth to get the best response possible. However, if you want to get a reel-to-reel for yourself then Welcome, you've come to the right place for help!
Edward. |
20th Mar 2017, 6:27 pm | #5 |
There is absolutely no reason why a tape recorded on one machine should not playback perfectly well on another, provided - The speed is the same, eg 3.75ips or 7.5ips and the track format is the same ie 2 track or 4 track. between both machines
There is always a possibility that the record/play head azimuth might be different between machines, but you will get sound, possibly slightly lacking in high frequencies. John |
20th Mar 2017, 11:35 pm | #6 |
There are several companies offering to transcribe old tape recordings to digital formats, at prices starting at £6.99 an hour. Knowing from personal experience the amount of time and care that the process takes, I think this is very reasonable. Search 'tape to CD' for options.
21st Mar 2017, 12:09 am | #7 |
See also the sticky thread on 'transferring tape to PC'.
Regards, Ben. |
22nd Mar 2017, 4:14 pm | #8 |
I realise I have a BSR TD2 deck in a home made case, it has no amplifier, I presume I can run the mono output to just about any amp 'gram' or 'ext' input ? Is there a (BSR) 4 track 3 speed deck that would fit in the same physical space ?
22nd Mar 2017, 4:19 pm | #9 |
Do you mean it has no electronics at all? The bare tape head has an output broadly similar to a mic or moving magnet cartridge, so will need a preamp to feed into a gram input. The preamp needs to apply equalisation too.
The 3 speed BSR TD10 is bigger than the TD2 (it takes 7" spools). The TD2 can be fitted with 2 or 4 track heads, but as a budget deck it wasn't used for 4 track much. |
22nd Mar 2017, 7:30 pm | #10 |
22nd Mar 2017, 8:23 pm | #11 |
Fair enough, but the TD2 only accepts up to 5¾" spools.
22nd Mar 2017, 8:32 pm | #12 |
Paul S. Yes the box has mains power and feeds for record , erase/bias (so omitting this one can do overdubs if you are very cleaver given there is no counter!) , and playback output, it may have a pre-amp in line with the output but I am fairly certain it doesn't.
23rd Mar 2017, 12:45 am | #13 |
So far Paul seems to be right on all counts! Overdubs might be possible Whyperion but surely a pre-amp would help or have I missed something
Dave W |
24th Mar 2017, 10:33 am | #14 | |
(I remember doing this donkey's years ago with a four track Tandberg 8, whose currently unused track is connected to the external 'FREE HEAD' connector on the back, in order to get stereo or if it was sound-on-sound I was after). |
27th Mar 2017, 9:18 pm | #15 |
Hi All
Sorry for delay in responding to all your comments - out of the country with work. Many Many thanks for all the good info - going to take time to digest it all but think I'm going to get a professional transfer done first - then maybe get a player to play with when free time allows. At least you all have widened my opportunities for a alternative deck. I'm done with this issue now as you guys have excelled yourselves - I'm heading over to the sticky thread 'tape to CD' as these will be gifts. Bye to All & Thanks again |
