28th Oct 2016, 2:04 pm | #1 |
Sony TC366 loud crackling noise.
I have several of these machines all giving superb audio, but one is working on one channel only and both channels have loud crackling noise. I have cleaned the heads and used Servisol on the switches, record level controls, the rotary switches on the back of the speed control and at the rear of the main control knob. I am coming to the conclusion it may be a cap in one amplifier, but dreading the thought of dragging the amp out, also it's many years since I last worked down to component level, in TV sets not recorders.
Gerard |
31st Oct 2016, 12:00 pm | #2 |
Re: Sony TC366 loud crackling noise.
I have not tackled the crackling noise fault yet because I thought I would have by now received lots of advice from the many experts on the forum, but alas nobody has helped so far. One thing I have done is blown out all the dust and then it played quietly on two channels, albeit with the same loud crackles. So it could be a bad soldered joint or an earthing tag etc. So it looks like I am alone with this fault so I had better start dragging out the amplifiers.
Gerard. |
31st Oct 2016, 12:49 pm | #3 |
Try wiggling the tops of the transistors in the affected channel(s).
Lawrence. Last edited by ms660; 31st Oct 2016 at 1:12 pm. |
31st Oct 2016, 1:47 pm | #4 |
Or you could try a slightly damp end of a finger across the pins, this often shows up a leaking transistor.
31st Oct 2016, 3:24 pm | #5 |
Thanks Lawrence and SP10. I will start to get underneath now but don' t know which amp is which. Have been looking on web for service data but cant see any. In my old TV service days I used to heat up or freeze microchips to check for faults but this is all transistor. Would that trick work on transistors? I should have mentioned that when I blew out the muck and dust the second channel only played for a few minutes.
Gerard |
31st Oct 2016, 7:21 pm | #6 |
Hi Lawrence and SP10. I have made a recording on the faulty machine and played it back on a good one. The right hand channel is very good without crackles but when I press down the left switch the noise is deafening with just a hint of music. I have tried to pull out the two boards but looks a major job, removing the bars on the chassis etc. Don't know which board is for record or playback. I have just seen the comments on the old Decca Bradfords and couldnt resist adding a comment.
Gerard. |
1st Nov 2016, 12:57 pm | #7 |
The service manual ought to be at hifiengine.com
What you describe does sound like a component failure in one of the amp circuits. I would follow the suggestion of tapping or wiggling transistors to see if it has any effect. |
1st Nov 2016, 1:04 pm | #8 |
Thanks Gulliver will do that. Looks like I have to dismantle more chassis members to get at the components so may institute more faults than I already have but don't have much choice.
Gerard. |
3rd Nov 2016, 1:28 am | #9 |
Since moving the amplifier boards out a little the machine is now erasing, recording and playing back on both channels but still with a loud noise on the left channel. Also when I switch on without any tape loaded up the noise is there mostly in the left channel. I haven't put any heat or cold on the transistors and caps yet as I can barely get near them, just a mass of cables covering the boards, I wish I could get to the boards as easily as I used to in my TV repair days.
3rd Nov 2016, 4:07 pm | #10 |
Tell me have you thoroughly cleaned the record/play switches on the circuit board?
Also yes a damp finger on the pins of a transistor can often show up if it has a dry joint (though not so common on old Sony machines), often the raucous crackling will stop for a while if you have located the correct transistor Gary |
3rd Nov 2016, 6:53 pm | #11 |
Philips KT3,
What type are the signal connectors on the back of the Amp? Phono or something else? (I don't know the age of the Sony TC366) |
3rd Nov 2016, 6:55 pm | #12 |
Oh i see it's a reel to reel recorder. Still, what are the connectors?
3rd Nov 2016, 8:07 pm | #13 |
Is there enough access for you to probe about with something long, thin and non-conductive like a chopstick or plastic knitting needle, in the hope of locating the faulty connection by deliberately disturbing it?
3rd Nov 2016, 9:19 pm | #14 |
thanks guys.things have changed yet again.will get back to you all in an hour or so with details Gerard
3rd Nov 2016, 11:34 pm | #15 |
The leads are RCA.yes I have poked around with stick.yes all switches cleaned with servisol.plays back tape recorded on good machine but only on one channel.if I plug in the second rca lead I hear the loud noise.If I turn on without any tape on machine the noise is there.unless I unplug one lead.Noise comes through headphone all the time.Records and plays back ok on one channel with one lead only but when I plug in the other lead that channel plays very faintly but with lots of noise.Gerard
3rd Nov 2016, 11:51 pm | #16 |
Why Sony designed the amplifier boards like this I will never know.Just another couple of inches in depth in the cabinet could have made a much easier layout.If any of you clever guys have ever removed the boards please tell me how.There are two dozen or so thin leads going to each board with looms going across both.Its hard to even see the transistors let alone tap them.But there is no use moaning about the design now ,the point is I have to fix the machine.I never gave up with a tv fault and dont intend to give up here.Hmmm,brave words indeed,Gerard
4th Nov 2016, 11:06 am | #17 |
Is RCA also known as Phono?
I once had an identical problem but with later SCART technology. Phono is more robust of course, but the socket boards can shift around during connection/disconnection if poorly designed. Try the freeze spray method shown on youtube? It is certainly capable of showing up duff ceramic capacitors for example. |
4th Nov 2016, 11:24 am | #18 |
Hi philpot. my comp go crazy with windows ten. will try send
Yes same phono. all ok there. I used freezer and heat years ago on tv sets but imposs to get to components on the boards. have you ever seen them on a Sony. its a jungle of wires covering them Gerard The fault could be simply a faulty cap across the mains input as the noise is there at switch on without any tape. Perhaps I am grasping at straws as they say. |
4th Nov 2016, 4:28 pm | #19 |
How do I release the clamp on the power cable.Any ideas.Gerard
5th Nov 2016, 2:07 am | #20 |
