Old 29th Mar 2011, 11:33 pm   #1
tri-comp
Default 2C34 Project taking off...
I was talking about an upcomming 2C34 Push-Pull amplifier-project here:
https://www.vintage-radio.net/forum/...d.php?p=393266
In the meantime there has been some development.
The chassis was cut, bended and painted as the following pictures will show.
I don't remember ever having seen pictures from the laser-cutting process or even having read a discription on how laser-cutting is done.
Probably you wont find it very interesting without pictures..... which is why I took a lot
The mechanical part is probably 80% or more but it's all done so not in a very distant future I will start actually doing some serious wiring. It will be rather uncertain just HOW the amplifier will look in the end. 2C34 requires some heavy driver-stuff which I have. I'll be using JAN 5687WA, a tough little cookie. Just don't know if it's tough enough. In order to get a reasonable output the 2C34 grid should probably be taken to +20V and 10mA which of course won't happen with that driver. DC-coupled cathode-follower ....or a pair of FET's between the 5687 and the 2C34 ....or something else.
Time for experimenting. As it is my first tube-amplifier it won't be easy.
The photos show the 2C34, 5687WA and Tung-Sol EF806SG
Now the pix.
Name:	2C34 009b_Stainless Steel with Foil.jpg
ID:	48823   Click image for larger version
Name:	2C34 027b_Cutting the Foil only.jpg
ID:	48824   Click image for larger version
Name:	2C34 035b_Cutting Steel.jpg
ID:	48825   Click image for larger version
Name:	2C34 042b_Cut Chassis.jpg
ID:	48826   Click image for larger version
Name:	2C34 075b_Cutting Buttom Cover.jpg
tri-comp is offline
Old 29th Mar 2011, 11:35 pm   #2
tri-comp
Default Re: 2C34 Project taking off...
more pictures...
Name:	2C34 106b_Lasercut Plastic insert for Bracket.jpg
ID:	48828   Click image for larger version
Name:	2C34 124b_Tube-Laser cutting Bracket-sides.jpg
ID:	48829   Click image for larger version
Name:	2C34 127b_Capacitor-Bracket Side-clamp.jpg
ID:	48830   Click image for larger version
Name:	2C34 136b_Lasercut Alu-plate.jpg
ID:	48831   Click image for larger version
Name:	2C34 151b_Alu-plate bended and ready.jpg
tri-comp is offline
Old 29th Mar 2011, 11:37 pm   #3
tri-comp
...and more
Name:	2C34 168b_Chassis partially bended into shape.jpg
ID:	48833   Click image for larger version
Name:	2C34 174b_Remove foil and Paint.jpg
ID:	48834   Click image for larger version
Name:	2C34 182b_Hammerite is just rite.jpg
ID:	48835   Click image for larger version
Name:	2C34 187b_Tubesockets and more.jpg
ID:	48836   Click image for larger version
Name:	2C34 190b_Under the Hood.jpg
tri-comp is offline
Old 29th Mar 2011, 11:38 pm   #4
tri-comp
final part
Name:	2C34 193b_Alu-plate populated.jpg
ID:	48838   Click image for larger version
Name:	2C34 197b_Steel and Glass.jpg
ID:	48839   Click image for larger version
Name:	2C34 200b_Glass up close.jpg
ID:	48840   Click image for larger version
Name:	2C34 201b_Alu-plate in place.jpg
ID:	48841   Click image for larger version
Name:	2C34 206b_Alu-plate detail.jpg
tri-comp is offline
Old 30th Mar 2011, 8:05 am   #5
cmjones01
That's very pretty - beautiful work. I hope you don't mind me asking, but have you prototyped the electronic design before doing all this detailed mechanical work?
cmjones01 is offline
Old 30th Mar 2011, 8:37 am   #6
tri-comp
He, he ... This is the chassis prototype and the electronics wasn't built beforehand.
This will be my test-bed and it will just HAVE to turn into a success won't it?
If it turns-out something is very wrong with design, I do have the opportunity to go and desing and make another.
But with the room inside this chassis and the tube-sockets chosen along with the transformer cut-out dimensions I should be able to get something usefull from this design. Different VVT iron will fit if necessary.
All is drawn in Solidworks CAD design software by my brother who is also the brain behind the laser-cutting.
He knows nothing about electronics which is where I step-in.
So, this is the very first design we made into production.
A much more elaborate chassis was designed before this one and will also be made into a proto-type soon. (EL34 PP with Lundahl iron)
Just, work seems to be more and more getting in the way of pleasure
Btw., the iron used in this amp. is from VVT Ltd.
They are at: http://www.vvttransformers.co.uk/index.htm
I had to take the transformers apart and paint the bells and the core.
Nice transformers at a reasonable prices and sloppy finish compaired with Edcor and Lundahl.
Still with the prices there is room to buy a little Hammerite
rgds,
/tri-comp
tri-comp is offline
Old 30th Mar 2011, 11:22 am   #7
cmjones01
Well, I wish you the very best of luck, and I hope it works eventually. Just remember that the components have no idea what you are trying to achieve, and they won't necessarily co-operate ;-)
Chris
Old 30th Mar 2011, 12:21 pm   #8
Peter.N.
Looks very nice, we had to cut and drill all our chassis by hand and then modify them when we decided to change the design - I wouldn't know how to use one of those things anyway.
Peter
Peter.N. is offline
Old 30th Mar 2011, 3:10 pm   #9
tri-comp
Aah, but I have almost 40 years of experience in tricking them into doing what I want
OK, if I have to settle with 5-6Watt output with a normal long-tailed pair as a driver I would also call that a success. It's just that I believe the 2C34 has a lot more potential to be exploited so before I call it quits I'll at least put up a fight
Unfortunately there's not a lot to be found on the WEB about 2C34 projects.
rgds,
/tri-comp
tri-comp is offline
Old 30th Mar 2011, 9:54 pm   #10
glowinganode
glowinganode's Avatar
That's lovely job you've made.
What value is the transformer primary A-A load?
I assume you're running them in push-pull (AB?) rather than class A strapped anodes.
Rob.
We have done so much, for so long, with so little, we are now qualified to do anything with nothing.
glowinganode is offline
Old 30th Mar 2011, 10:51 pm   #11
tri-comp
More pictures as a little was added today.
I really want to run them as P-P, I'm not a SE-person.
Take a look at the attached data sheets for those interested.
OPTransformer data is here:
http://www.vvttransformers.co.uk/vtp..._datasheet.htm
I was figuring that with all these secondaries and UL-taps SOME mix should fit the 2C34 setup.
rgds,
/tri-comp
Name:	2C34_ 003b_Front view.jpg
ID:	48878   Click image for larger version
Name:	2C34_ 004b_Rear view.jpg
ID:	48879   Click image for larger version
Name:	2C34_ 002b_Bottom View.jpg
tri-comp is offline
Old 1st Apr 2011, 9:30 pm   #12
tri-comp
Some more added under the hood.
rgds,
/tri-comp
Name:	2C34__ 001_b.jpg
ID:	48962   Click image for larger version
tri-comp is offline
Old 10th Apr 2011, 1:34 pm   #13
tri-comp
It became time to start messing with electronics.
Since I'm no constructor and have very little experience in designing electronic circuits (I'm used to repair electronics, not to build it) I'll have to ask for your opinions on what I've drawn-up.
The 2C34 should be run in Class-B to get something usefull from it.
That means pulling up to 10mA of G1-current and supplying around 100Vpp G1-to-G1
Since the G1 Bias should be around -15V I suppose that would mean swinging each grid from -65V to +35V PEAK corresponding to approx. -45V to +25V RMS
(Above values taken from the Raytheon data-sheet.)
To this end the Catode-Follower (CF) with a CCS is used, ref the schematics.
Now my question; what necessary current should I expect to be needed through the CCS?
The transistor (MJE340) should regulate easily down to 1mA but let's make it 2mA just in case. The diode string current will be 1/10 of that.
The 10mA of G1-current will be supplied through the CF from B+ when swinging the grid positive but should the CCS be running this current plus the 2mA?
The CF (5687WA) will start sweathing if loaded with a constant-current of 12mA I think, not mentioning the power-transformer that will have to supply 4x12mA extra, one for each CF.
Also, how much negative voltage will be needed for the CCS? Entry point of negative supply is common point of R3/R4/R13 & Diode-strings. Will 125-150V be enough? ..and why?
B+ is aroung 330V. A bit high but hopefully nothing to worry about. I'll possibly have to drop it a little for the CF, depending on the choice of CF-valve. So far: 5687WA.
The component values in the schematic hasn't been calculated yet. When they are I'll post a new schematic with every detail added, this is just a draft.
Phase-splitter will be a concertina-variant with a pentode in front (6AN8A)
Mostly because I ran out of tube-sockets
rgds,
/tri-comp
tri-comp is offline
Old 10th Apr 2011, 3:58 pm   #14
glowinganode
Hi, this is as far as I got with mine.
I decided transformer coupling the grids was a much neater method instead.
This saves a seperate negative supply, several valves and associated components and avoids variation in standing current due to drift in the cathode follower.
Good luck with the design, sounds like you've put a lot of though into it.
A few mA's standing current should be fine.
Rob.
Old 10th Apr 2011, 4:56 pm   #15
tri-comp
Hi Rob,
I remember your project went dead about here.
I do agree about the transformer-solution it's just not so easy to experiment with transformers. You've got to live with what you have. Not so with CF's and CCS. There is a lot of room for experiments. Different valves, CCS with a pentode (...aah, but not enough socket-holes punched out ) and more.
Besides, who can say exactly in the first go, what transformer is going to work in this set-up. Not a lot of experience to be tapped into on the web.
Stay tuned, I'll at least end up with 5 Watt
Best,
/tri-comp
tri-comp is offline
Old 11th Apr 2011, 11:37 am   #16
dominicbeesley
dominicbeesley's Avatar
I was thinking about this earlier this week the cathode follower will need to source a lot of current to pull the output valves grids high but will it need to sink as much - the grid current will be battling to pull them back down?
My amplifier is stuck due to my ropey metalwork skills - I tried to make some cap holders but they broke after about ten minutes!
D
dominicbeesley is offline
Old 11th Apr 2011, 7:33 pm   #17
glowinganode
No, you're right. This is an ideal application for a cathode follower.
The amount of pull down current is very small, but needs to be high enough to achieve a decent slew rate on the negative going cycle.
It has to overcome the capacitance of the grid - cathode of the output tube and cathode - heater capacitance of the c/f.
A couple of mA's is usually sufficient.
A pentode might make a more linear c/f due to its constant current nature.
Rob.
Old 11th Apr 2011, 9:35 pm   #18
tri-comp
D, My cap-holders would equally break after a few minutes if I didn't have access to a tube-laser. Now feel free to drive over them with a truck
Glowinganode, thanks it is this info about the pull-down current I was searching.
The semiconductor CCS i drew-up is just a draft.
Morgan Jones knows just how to make them i real life, ref attached doc.
PS.
Don't really know if publishing this info on the forum is OK with copyrights.
If not, moderator feel free to delete.
rgds,
/tri-comp
tri-comp is offline
Old 11th Apr 2011, 11:06 pm   #19
glowinganode
I found this quite interesting.
Rob.
Old 12th Apr 2011, 8:09 am   #20
tri-comp
I already read these interesting pages.
Nothing beats solid experience coupled with deep insight.
Still, the PowerDrive may seem more like an OverDrive to my poor 2C34'
They are already split down the middle right to the common katode
I can't locate the 10M45 CCS-chip locally unfortunately. Otherwise I would use it for sure. I've already got some Texas Instruments TL783 but they are only good to 125V, at bit on the low side.
rgds,
/tri-comp
tri-comp is offline
