Old 15th Nov 2018, 8:06 pm   #1
stuart_morgan_64
Default Heater element advice
I have a Miele rotary iron which failed a pat test. Using a insulation tester it is leaking to earth.
Is it possible it has got damp, element on isolation transformer at the moment, is there anywhere that can make elements, or any other suggestions please.
Thanks
stuart_morgan_64 is offline
Old 15th Nov 2018, 8:21 pm   #2
Boater Sam
Default Re: Heater element advice
Cook the element out of the ironer, get it good and hot. if necessary unseal the ends, cook it till the insulation is well and good and reseal with high temperature silicone ( flue sealant).
Common element problem in cookers.
Boater Sam is offline
Old 15th Nov 2018, 8:49 pm   #3
stuart_morgan_64
Ok. I thought perhaps. I only have a 2A isolation transformer. Wound the variac to 2A current draw. Element was half a meg. After about 20 mins when i left inceased to 5M plus.
Old 15th Nov 2018, 11:30 pm   #4
McMurdo
McMurdo's Avatar
Sounds good, I keep meaning to do the same to my dads hostess trolley.
You can get a custom made element from Midland Elements in Longton if the original element needs replacing and isn't available as a spare.
http://www.hightemperatureelements.co.uk/
Kevin
McMurdo is offline
Old 16th Nov 2018, 10:30 am   #5
Hunts smoothing bomb
Hunts smoothing bomb's Avatar
I think you will need to unseal it and cook it though as if you don't then the moisture evaporates to a gas and the resistance seems well qnd good but the moisture is still trapped inside the casing so when the element cools it condences again and you are back to a low insulation value.
Lee
Hunts smoothing bomb is offline
Old 16th Nov 2018, 2:02 pm   #6
stuart_morgan_64
I would of thought if the moisture can get iƱ, it can get out?
Old 16th Nov 2018, 2:11 pm   #7
Refugee
Refugee's Avatar
If you can apply 24 volts to it for a long time perhaps a couple of days it should dry out but will need to be used regularly in order to stay dry.
Refugee is offline
Old 16th Nov 2018, 4:08 pm   #8
stuart_morgan_64
It will be used daily. Not been to the workshop to check the elements today. Yesterday was looking promising
Old 16th Nov 2018, 5:39 pm   #9
G6Tanuki
G6Tanuki's Avatar
I successfully 'restored' the elements in an old cooker which lived in an outbuilding and was only used for a few months a year (to boil up 'mash' for the owner's hens) by blasting the elements with an industrial heat-gun (powerful enough to solder 15mm Yorkshire fittings).
As others have said, the problem is moisture creeping into the mineral-insulation between the element and the outer jacket.
Get it hot - a few hundred Centigrade hot - and keep it hot for a few hours.
G6Tanuki is offline
Old 16th Nov 2018, 5:57 pm   #10
thermionic
thermionic's Avatar
Just stick it in a domestic oven turned to 200 degrees.
That will drive out the moisture, without resorting to passing current through it. Whatever suits you, really!
Cheers.
SimonT.
The honesty of imperfection..........
thermionic is offline
Old 16th Nov 2018, 6:05 pm   #11
ex seismic
There are some areas that look potentially rusty. Check that it hasn't pin-holed in those areas. If it has then it will need to be kept in a dry place and used regularly. Or get it good and dry and seal those areas with metal (aluminium) duct tape.
ex seismic is online now
Old 16th Nov 2018, 7:12 pm   #12
Herald1360
Herald1360's Avatar
The ally tape might not suffer but the glue'll stink, at the very least......
....__________
....|____||__|__\_____
.=.| _---\__|__|_---_|.
.........O..Chris....O
Herald1360 is offline
Old 17th Nov 2018, 5:32 pm   #13
stuart_morgan_64
One is almost stopped leaking, the other on its way down, fingers crossed, thanks for comments.
