10th Nov 2016, 6:32 pm | #1 |
Mystery metrology question
...What is it?
I am advised that (a) former owner was connected with the GPO and also with Tank warfare. Gun laying? cable laying? Depth measurement? (Probably not the latter as it has no ad.patt. reference) It is quite small and has an FSD demand of 1mA. When protected with 8.2kohm it gives an FSD of 9volts, and is likely to end up in use as a voltmeter or a petrol contents gauge |
10th Nov 2016, 7:28 pm | #2 |
Re: Mystery metrology question
It could be from a GPO reflectometer. Was GPO kit of that era marked with a broad arrow?
10th Nov 2016, 7:39 pm | #3 |
AP..... suggests airforce.
Radar rangefinder readout?
10th Nov 2016, 8:41 pm | #4 |
Could be radar (but a ground based set as it has no backlighting?)
Time Domain Reflectometry a possibility. The compactness, light weight and surface mount flange hint at portable equipment and simplicity of quick testing by substitution.. |
10th Nov 2016, 8:44 pm | #5 |
If you google model 909 meter you'll find all sorts of examples with various scales. This one appears to have been part of a range finder. Maybe it was used to find the range of your enemy so a tank could shoot at him?
Stuart The golden age is always yesterday - Asa Briggs |
10th Nov 2016, 8:55 pm | #6 |
I thought AP meant Admiralty Pattern, but Airforce and Army also fit! Either way it's possibly for test equipment of some description. 7000 yards is about 6.4km or 4 miles.
10th Nov 2016, 8:58 pm | #7 |
I can't remember any GPO equipment being marked with a broad arrow.
10th Nov 2016, 8:59 pm | #8 |
Might the reference be associated with an 'Air Publication' document?
Richard (trh01uk), perhaps you can advise ... Best wishes Guy
"What a depressingly stupid machine." [Marvin: HHGTTG] |
10th Nov 2016, 9:24 pm | #9 | |
http://picclick.co.uk/Vintage-Volts-...104615814.html and here's one for 10 mA which also indicates it was manufactured by Ernest Turner http://www.ebay.co.uk/itm/DC-Milli-A...p2047675.l2557 It still doesn't tell us what the above one was for but 4 miles sounds about the right range for a tank shooting at something. It's a bit short for a naval gun.
10th Nov 2016, 10:35 pm | #10 |
I am totally confident that 'A.P.54959' on the dial means 'Admiralty Pattern 54959'.
'A.P' meaning 'Air Publication' is never seen as a reference on an item of hardware, but as the reference (with accompanying digits) on a document. The Stores Reference for an Air Ministry or RAF meter would be typically 5Q/xxxx or 10A/xxxx Andy |
10th Nov 2016, 11:44 pm | #11 |
Andy I suspect you are correct. I was looking for AD PATT at the very least but as the meter is very small AP is understandable. Finding a reference to 54959 is proving a challenge though. There is a good reference to WW1 numbers but later ones, no such luck.
I am winging it a bit, but Gunlaying wise this might correspond to the range of the guns on a small vessel- eg corvette. |
11th Nov 2016, 12:04 am | #12 |
Don't think its off a tank early on it was normally done with mk1 eyeball most early tanks had a limited maximum range against another tank on a Sherman for example about 800 metres. Then on more modern tanks like Chieftain they then used a ranging gun and today laser and ranges increased (starting with Centourian and its 105mm gun) after Centourian and onto Chieftain ranges were measured in metres (Certainly at the start of the 70s) not much help sorry!
11th Nov 2016, 12:38 am | #13 |
IF we take the Admiralty connection as a good one, the other possibility is testing of cables destined for underwater signals/comms. The date is right in the hot part of the cold war, and elements of passive listening devices and submarine shenanigans were of course kept very dark.
11th Nov 2016, 8:26 am | #14 |
perhaps a display of expected range of a shell from a large gun, whether a self-propelled land one (E.G. Abbot SPG, which looks like a tank) or a naval one?
11th Nov 2016, 10:16 am | #15 |
I can't recall seeing something like that in a British AFV, to any gunnery it would be like putting a 1/4" dial on a Short Wave set.
Andrew
11th Nov 2016, 10:22 am | #16 |
I would imagine that a small meter like this one is likely to have come from a Test Set for some item of Admiralty equipment.
Andy |
11th Nov 2016, 4:54 pm | #17 |
Could it be wire paid out when using a wire guided torpedo?
D |
12th Nov 2016, 1:17 am | #18 |
I'm putting my bet on the suggestion in post #3: to be used to supplement a 'scope trace in a ground-based Radar station, e.g. Chain Home. It's a pity M.G. Scroggie isn't with us any more: he would have known with certainty.
Al. |
26th Jan 2017, 2:47 pm | #19 |
I was reminded of this thread when I watched a short fim today. Have a look at the link (its a youtube film) and go to time 2:36. There's a device there which is new to me...where is it from?
https://www.youtube.com/watch?v=UTO0ogdNMdY The film is a little odd...you dont have to watch it all david |
26th Jan 2017, 4:50 pm | #20 |
I think this might be the original:
http://pa0pzd.com/airforce/aaf-altit...vers/bc-788-c/ Don't ask me how I found that. The AR88 knobs were a clue. Lawrence. Last edited by ms660; 26th Jan 2017 at 4:58 pm. |
