16th Nov 2018, 11:29 am | #1 |
Replacement Philishave Rechargeable Battery
My Philishave shaver, Model HQ6849 rechargeable Ni Cad battery has kicked the bucket and a quick search online provides a NiMH 2000Ah type as a replacement.
Would this type be suitable and would there be problems with charging ? Your advice would be welcome.
When I die, please don't let my Wife sell my collection for the amount I told her I paid for it! |
16th Nov 2018, 11:35 am | #2 |
Re: Replacement Razor Rechargeable Battery
If this is the 'wet and dry' type I changed the batteries in mine for the 'NiMH type a number of years ago and its still going strong. Brilliant shavers.
Tagged batteries available on ebay. Peter |
16th Nov 2018, 11:41 am | #3 |
Do you know what the capacity of the original battery is? I suspect it will have been rather less than 2000mAH. 700 to 1300mAH were typical values for NiCd cells.
If the charging circuit uses a simple series-resistor then fitting a larger-capacity NiMH battery should be OK, it'll just take longer to charge fully. If the charging circuit includes any sort of sensing system (like a diode to detect the battery getting hot) and a charge-cutoff circuit then this will not necessarily be NiMH-compatible though you'll probably get away with it, just keep an eye on it for the first few charges and see if it gets hotter than the old one did. |
16th Nov 2018, 11:52 am | #4 |
Charging is likely to be suboptimal but it probably won't matter. It may be better not to leave it permanently on charge when not in use.
16th Nov 2018, 12:04 pm | #5 |
G6Tanuki,
I have the original battery (just removed it) and not any info on it, except Ni-CD, Recycle but there is this string of numbers: 1.800.822.8837 (probably a Philips part number?) and it's the original one fitted from purchase some years ago,
16th Nov 2018, 12:09 pm | #6 | |
Peter N,
16th Nov 2018, 12:12 pm | #7 | |
Paulsherwin,
16th Nov 2018, 12:14 pm | #8 | |
If there's a Philips model-number on the shaver itself it may be worth searching for an old online ad for it which may give some specification details that include battery capacity. |
16th Nov 2018, 1:05 pm | #9 |
If you're really worried about MiMH problems, you can still get full fat NiCd.......
https://uk.rs-online.com/web/p/aa-re...eries/3783326/
16th Nov 2018, 1:10 pm | #10 |
Herald,
Well spotted & I also need to place an order for other items too. Cheers P.S. Here's a pick of the razor:
When I die, please don't let my Wife sell my collection for the amount I told her I paid for it! Last edited by camtechman; 16th Nov 2018 at 1:25 pm. |
16th Nov 2018, 4:38 pm | #11 |
Being fed up with funeral adverts on TV, I decided to have a go at the shaver and in my box of "one day they'll be handy" batteries in the cupboard, I came across a Ni-MH AA battery that looked unused with a rating of 800 thingy-ma-bobs.
30 minutes later, having blown away my previous beard shave, fitted the battery, re-assembled I plugged it in and WHOOPIE it started to charge and I'm leaving it to charge for an hour. I cheated after 15 mins and it worked well and again after another 15 mins...……...I'll report later...… Cheers
16th Nov 2018, 7:08 pm | #12 |
Nothing to lose- worst case is just a dead NiMH but that'll probably take a few years!
Shaver looks remarkably familiar, though...... Guess they didn't reinvent the wheel.
19th Nov 2018, 12:20 am | #13 |
the one in my philishave is the same thickness as an AA and the same length as an AAA. It's an NiMh, an AA size is too long to get inside, it's the same shaver as post 12.
I scrapped the shaver as the proper philips battery was too dear.
Kevin |
19th Nov 2018, 1:15 pm | #14 |
Bother..... the cell in mine isn't wonderful- only about 2-3 shaves per charge these days.
Edit: Took mine apart and found it's definitely an AA size NiMH in there. Phew!
....__________ ....|____||__|__\_____ .=.| _---\__|__|_---_|. .........O..Chris....O Last edited by Herald1360; 19th Nov 2018 at 1:30 pm. |
19th Nov 2018, 1:29 pm | #15 | |
Cold comfort here: https://www.batteriesplus.co.uk/acat...H_Battery.html
19th Nov 2018, 7:44 pm | #16 |
Surely "stick it back on charge for a top-up after after every use" would be the expected duty-cycle??
19th Nov 2018, 10:36 pm | #17 |
Re: Replacement Philishave Rechargeable Battery
Maybe for an electric toothbrush which sits on a charging stand but the shaver has to be plugged in using the same lead as a mains operated one would have. Since there's a relatively complex switchmode fast charger built in I don't think it was designed for other than "charge it when it's flat" service.
Certainly it would go quite happily for a couple of weeks- probably ten shaves or so when it was new. It's on its third set of cutter heads now, so it hasn't done too badly, but £3 for a battery is more attractive than £30 for a new shaver!
19th Nov 2018, 11:53 pm | #18 |
This is an excellent site for finding cell types from their dimensions. Scroll down to see the table.
https://www.powerstream.com/Size.htm Al
I won't tell you how I discovered that. |
22nd Nov 2018, 7:10 pm | #19 |
Location: Near Lichfield, Staffordshire, UK, most of the time and Crystal Palace, S London, some of the time..
Alistair, thank you for that page it’s a mine of useful information.
Ian |
22nd Nov 2018, 8:40 pm | #20 |
Just an update, my razor is still working fine, since I fitted the 800mA NiMH Battery.
