19th Jun 2020, 1:17 pm | #1 |
Sony TC 800A Portable R2R
Hi everyone and another question ref the Sony TC800A portable R2R.
The actual mains lead that connects to the body of the unit is very difficult to obtain but, the 12volt battery lead comes with the essential mains plug that fits the body, question is, is it possible to convert a 12 volt lead and stabiliser to a 110/120 volts lead. The internal transformer says 110/120 volts on it, there is no mention of the unit being a 240 volt machine, is this correct? any advice is welcomed |
19th Jun 2020, 4:48 pm | #2 |
Re: Sony TC 800A Portable R2R
There seem to have been several models with mains transformers wound for different voltages. If yours is an American-sold one it might well be 120V only.
Alas you can't convert the battery lead (safely) into the mains lead. There are 4 holes in the connector, 2 for mains, 2 for 12V input and only the appropriate ones are fitted with contacts in each lead. As the connector is moulded, you can't move the contacts around. And whatever you do, don't re-wire the machine to put the mains input on the '12V' pins, somebody will either plug a 12V lead into that machine and burn out the transformer or use your 'mains' lead with some other Sony device and apply mains to the 12V circuitry. Given you have a 120V machine which would need an external transformer to run it in the UK, you might find it easier to just make a small 12V power supply and connect the 12V lead to that. I've attached a circuit diagram that I traced out of the regulator unit in the 12V cable, just in case it's any use. |
19th Jun 2020, 4:54 pm | #3 | |
