16th Jun 2020, 4:09 pm | #1 |
Rotel RD-865 Won't Play
Hello all,
Just wondered if anybody has any diagnostic advice. I have a Rotel RD-865 that won't play. The belt is intact and the transport fast-forwards and rewinds (although it's a dual motor system.) When play is pressed the head carriage moves in to position, the capstan starts for less than a second and the carriage drops down again. The unit then locks up and needs to be powered down and restarted. Until this the transport controls do absolutely nothing. I would suspect that there's an IC waiting for an input or getting one it doesn't expect. It detects the tape type when a cassette is inserted and I've tried a few different cassettes. It's cosmetically a perfect and a nice unit so I would really like to get it working again. Anybody come across this before? Cheers, RR |
16th Jun 2020, 7:49 pm | #2 |
Re: Rotel RD-865 Won't Play
I have no knowledge or experience of this unit. Looks a good model.
When the problem occurs does the tape type indicator stay lit or does it go off/flash ? David |
16th Jun 2020, 8:55 pm | #3 |
Thank you for the reply
It stays lit, so I don't think it's those switches causing it. I've tried metal and chrome tapes with no difference. Its got to be better than the nasty old early 80s Sharp that's currently in the system! |
17th Jun 2020, 9:07 am | #4 |
As it has 2 motors I suspect 1 is for the capstan/loading and the other for spooling. If the spool motor isn't starting than the mech may well shut down to stop chewing tape. Clean all switches on the deck. Unused for years they can tarnish and cause various problems.
Have you got a service manual? |
19th Jun 2020, 4:50 pm | #5 |
Hi!
Any help? Chris Williams
