Old 4th Aug 2020, 11:33 am   #41
GSBX1220
Default Re: PCB Artwork transfer
Hi Folks
Another one late to the party. I have started making my PCB's again. I was always a bit old school in the past and used the PCB transfers available from Marlin back in the day.
I still have some, but I'm running low. Very low! I now need to up my game and start designing layouts on PC or my raspberry Pi
Question is, what software is commonly used that has a library of IC pinouts, solder pads, tracks etc?
I plan to use the press n peel method.
Richard.
Richard
GSBX1220 is offline
Old 4th Aug 2020, 12:11 pm   #42
Wendymott
Wendymott's Avatar
Hi Richard. I use DIPTRACE... my version is 2.4 There are later versions, but it is not free. I think mine cost about £250 .... but I built a comprehensive library for my personal needs....... There are lots of other PCB / Schematic packages available, but I use this.
Other members will have a "million" suggestions
Should get out more.
Wendy G8BZY
Wendymott is offline
Old 4th Aug 2020, 3:09 pm   #43
Scimitar
Scimitar's Avatar
I was frustrated with all of them until I tried EasyEDA. They will also make your boards at stupid prices like $2 for ten plus postage! I think they make their money from the Fedex shipping but you can opt for airmail which they sit on for ten days so that you might choose the fast Fedex service instead!
Scimitar is offline
Old 5th Aug 2020, 10:33 am   #44
Wendymott
Wendymott's Avatar
I will not tie myself to a board supplier based software... I use PCBWAY in China for my "Finished" modules.... I home etch all my prototypes..using either Photo processes or Iron on Toner. But in this game.... everyone has his / her preferred way. No one is right.. no one is wrong.
Wendy G8BZY
Old 5th Aug 2020, 10:58 am   #45
Slothie
Personally I use KiCAD because of its great price and because I went to the effort of its steep learning curve! I did use Eagle but got frustrated with its 100mmx80mm max on the free version and the fact that to get larger boards required buying the £1000 version. A lot of the other competitors have moved tp a subscription model that for my level of usage isn't really an option.
I tried Diptrace, and it did seem OK to me and the price isn't terrible. I like the idea of having a program that I own and could theoretically fire up in twenty years time to access my schematics and
board layouts even if I have to run a VM in my 2000 core optical hyperprocessor, so a product that could go away at the whim of the company that makes it either because the online service goes or the licence server discontinues isnt appealing.
For these reasons I never realy looked at EasyEDA despite all the glowing comments I see; however I noticed a few weeks ago they offer a downloadable version that should theoretically work offline, so if I was looking again I'd consider it especially considering its links to suppliers etc. However the new KiCAD 5 is looking good for me at the moment, even though it seems if I need to rework some of my older designs the changes to the libraries are going to cause a little work.But all my old designs still produce gerbers from the cached symbols and footprints, so its only a mild inconvenience.
Slothie is offline
Old 5th Aug 2020, 12:16 pm   #46
Scimitar
Scimitar's Avatar
It isn't tied. The software will produce Gerber files or even images for home etching. The production is an option that I felt was worth it.
Scimitar is offline
Old 5th Aug 2020, 12:22 pm   #47
Scimitar
Scimitar's Avatar
That's how I use it. You can keep your files locally, online or both. I keep mine online currently because it means that I can take up a few spare minutes at work with some tweaking. The routing program is nothing short of amazing.
The other option it has is "team working". Haven't got that sussed yet, but it would appear that a friend can be nominated to access your work and view it or modify it if relevant permissions are set.
Having tried KiCad, Eagle and the RS free version, EasyEDA was useable without lots of complication and logical enough not to need to keep referring to manuals.
Scimitar is offline
Old 5th Aug 2020, 12:50 pm   #48
GSBX1220
Hi Folks
Thanks for the replies.
As I'm only maybe doing at most maybe one board a month, I was looking for something what would be freeware or such. I know that type of software would have limitations, but for light hobby use I would work round that.
If the rub on transfers were still available, I would most likely continue that way as like I said my boards are low volume and simple.
Richard
Richard
GSBX1220 is offline
